I have vaio desktop, my sony dvd player stop working, any help is grewatly appreciated
  • 2 more comments
  • alexholeinon Jul 01, 2009
    No, it doesn't recognize any dvdor cd, but the system recognize the drive and when i click the eject button it does eject the dvd or cd HELP
    yes i click the eject button while the desktop is running and it ejects the dvd or cd, and when i pressed the eject button on the side of the desktop, it ejects sometimes but not all the time
  • menlotech May 11, 2010
    if it stopped working, does this mean that you press the eject button when the computer is running and it will not open? How about if you launch into the system BIOS? Does it mean that you had a CD or DVD in it and it will no longer respond?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    is the dvd player recognizing any discs you put in there?
  • 22 Answers
Most likely the drive is bad. They are fairly simple to replace. Just go down to your favorite Big Box store and buy a DVD drive off the shelf.
Assuming this is no longer under warranty of any kind, you can just take the side panel off and look and see whether it's got a big, wide "ribbon cable" going to it or if it's got a small, narrow cable going to it.
If it's a big, wide cable, you'll need an IDE DVD ROM. Those can be had almost anywhere, but I personally like NewEgg.com for this sort of thing. If you are in a hurry, you can go down to your local Wal-Mart or computer store and pick one up there, but you'll pay more for it, in all likelihood. If it's a small, narrow cable going to it, then it's a newer SATA drive.
I would not spend more than about $20-25 for a DVD ROM drive. You can pick up a DVD burner for about $50. Again, make sure that you figure out of it's IDE or SATA as it makes a difference.
Once you have the replacement drive, turn off your computer, unplug the power cord and push the power button to discharge the capacitors. I recommend the following procedures be done on a hard-surface to reduce static build-up.
There are probably 4 screws holding the old drive into the case, two on each side. Unscrew them and unplug all cables from the old drive. Slide the old drive out and slide the new one in and connect the cables back where they were on the old drive. They should only go in one way, but if the data cable (a flat wide multi-wire cable with a single color stripe most likely) will go in either way, you typically want the colored stripe to go towards the power connector. Typically they are "keyed" either by a bump on the top or a missing hole in one spot to make it impossible to put the cable on wrong. Be careful as it's easy to bend the pins when removing or replacing the cable. BE GENTLE!!!
Once you have the new drive in position, use the screws you took out of the old drive to secure the new drive in place and prevent it from sliding around. Then, power it on and wait for the new drive to be detected.
Posted on Jul 01, 2009
My Sony RS530G randomly stops producing all sound (System, itunes, Real Player, etc.) Restarting or hibernating cures the problem for a while. This makes me suspect a hardware problem vs software. Any...
You may need a better sound card. While you're at it, if you update your display card, you'll be offloading actual memory while video card's own memory picks up the slacker.
Sep 28, 2017 | Sony VAIO PCV-RS530G PC Desktop
I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
Sony Vaio VGN-AW21M OPTICAL DRIVE PROBLEM
replace drive 35-50 bucks i reccomend a lite on
Aug 22, 2009 | Sony VAIO VGC-RA840G PC Desktop
My DVD player does not work Cannot recognize
I think you have turned off the Autorun facility if you do so reenabl it and give me a clarification also
Jun 17, 2009 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
Can't open DVD writer and Dvd Rom drive Sony Vaio VGC-RB 34G
There should be a very small hole on the front of the dvd plate. Push a small paper clip straight in. This should release the drive.
Apr 16, 2009 | Sony VAIO VGC-RB34G (670737601) PC Desktop
Sony Vaio with Vista has stopped reading Data CDs
make sure windows media player is not starting on boot up if it is running in the back ground it can cause simialar problems.
Feb 11, 2009 | Sony VAIO VGN-FS640W Notebook
Dvd player will not play movies or video clips, only cd will work
The DVD player function on most PCs will not work unless you have the correct codec.
If you want to play movies... I suggest you download a trail of POWERDVD or WINDVD
Use google.com to find the download. It will install the proper software needed.
for AVI files and the like.... use VLC media player. It is free.
Good LUCK!
Sagacious1
Dec 07, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Software Problem burning CDs
during this period, did you have anti virus turned off?
Jun 02, 2007 | Sony VAIO Digital Studio PCV-RS430G PC...
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
