Question about Epson Stylus CX3200 All-In-One InkJet Printer
Indicates paper jam,I followed troubleshooting for paper jam, still get error message
    Scholar:
  • 38 Answers
From another site...
"This can be caused by anything obstructing the carriage area, like a
paper clip or small scrap of paper. The other reason this may occur is
if the lubrication for the head carriage becomes sticky or dried out.
Usually to correct this, check the rails or guides that the head
carriage rides along, and clean them with a lintfree cloth. Then
replace the removed lubricant with an appropriate type of lubricant
(3in1 or sewing machine lightweight machine oil for oiled contact
points, a lightweight lithium grease for greased areas."
I also know that any paper jam, or bum can dismantle springs and bits and pieces inside, as it's a common error with a lot of printers.
The only 2 things I can suggest are too..
Search Online and find the Manual for your printer, and see if it's in the FAQ or support for common issues.
OR.. what I usually do, like yesturday when I worked on a client's printer with the same error, is to dismantle the back, take off the cover, and depending on the model, there are usually springs or an arm that works with the feeding of the paper and/or direction of it. If they are not in the correct place/look bent, etc. Play around with it.
Otherwise there isn't much else you can do. Printers are not worth repairing, and the manufactures do not count such issues under warranties - bastards. ( >=( ) so other than that, buy a new cheapish one.
Hopefully I have been of some assistance!
Posted on Jul 01, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
How do I get the paper jam error message to turn off after fixing jam on Dell C2660 printer
Turn the power off and let it sit for a few minutes. While it is off, open all the paper path access areas and check for any pieces of paper or buildups which may affect a sensor.
Close it back up and turn it on.
Here is a link to the manual, which has two good areas covering paper jam troubleshooting and resolution (around pg 300). http://www.manualslib.com/download/577729/Dell-C2660dn.html
Mar 03, 2015 | Dell Color Printer - C2660dn
I got the error message on my Lexmark C532n 200.26 and 200.16, there is no paper jammed, the Lexmark technician asked me to change the paper pick up roller which we did, but we are still getting the error...
The 200.16 jam indicates that the input sensor was covered when the printer was powered on or reset, or a cover was opened/closed.
You may also check the following:
1. The paper being used is within specification and has been loaded correctly.
2. Any previous jams have been completely removed.
3. The printing environment is within acceptable temperature and humidity ranges.
4. If the tray was overfilled or a paper jam occurred, sheets of paper may have come off the media stack.
5. If you don
Feb 01, 2011 | Lexmark C532n Color Laser Printer
I have a Brother HL-4070CDW printer and the display shows "Jam Tray 1 - Remove the jammed paper from Tray 1". We have followed ALL of the troubleshooting instructions from the Brother manual and...
hello, sorry to say that your machine will need the entire front door assembly, whats happening, is that the guide for paper feed, well it now has problem, so far the only way to fix it, is to replace this part, i have tried alot of temp. fixes, but only last a few days, and then it comes back, sometimes worse.
Oct 27, 2010 | Brother HL-4070CDW Printer
Carriage Jam problem. Have gone through complete troubleshooting routine, but the message just won't go away. Says ""Carriage Jam". No debris to left or right of carriage. In fact, the jam was in the paper...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Dec 20, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
