Question about Panasonic KX-T7731 Corded Phone
For KX-T7730 how do you set /change date/time and date ? Also day like mon tues etc ?
  • 2,119 Answers
OK -here is a link to the users manual. Section 4 is system programming. Page 4-9 In section 4.2 has the instructions to set the Time and Day. http://www.voicesonic.com/panasonic/manuals/KX-TA308-616_System/KX-TA308_InstalationManual.pdf For KX-T7730 how do you set /change date/time and  - cleardot.gif http://www.voicesonic.com/panasonic/manuals/KX-TA308-616_System/KX-TA308_InstalationManual.pdf
Posted on Aug 14, 2014
SOURCE:
SOURCE: Date/time change
Press program
then 0
(this will then display current date and time - overtype as follows)
eg. for Friday 2nd November 2007 8:58 am you type the following
071102 (date backwards) [space] 5 (Friday is 5th day of week) [space] 0858 (time) [space] 0 (0 is am, 1 is pm)
Press the store button and then program button to exit the programming.
Posted on Nov 02, 2007
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
Posted on Apr 08, 2008
  • 108 Answers
SOURCE: Panasonic KX-T7730 corded
If you can provide the phone system type I will try to help as this is a system wide setting and there are a lot of different Panasonic systems out there. ......Mike
Posted on Aug 02, 2008
SOURCE: Change the time and date on Panasonic KX-T7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
Posted on Nov 04, 2008
cnavarro
  • 2460 Answers
SOURCE: How can I change the date and time on a Panasonic KX-T7730
From the phone connected to Jack 01 (usually 101) press PROGRAM *#1234 and dial 000 and the SP PHONE button. Your display should show a blinking cursor over the year. Use the FWD and CONF buttons to go forward (and back) and the AUTO ANS or keypad to change the entries. Finish by pressing STORE
Carl
Posted on Sep 17, 2009
HOW DO i CHANGE TIME ON PANASONIC TELEPHONE KX-T7730
Press Program
0
you will see a display (January 19, 2011 - display 110119)
enter your date (don't press any other buttons, the phone will do in sequence)
YYMMDD
enter day of the week (1-Mon, 2-Tues, so on)
enter time (don't forget to enter 0 if like 9:30)
0930
enter AM or PM (0-AM, 1-PM)
0
then press store button
then press program button
you should see your date and time display
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
How can i set time and date in panasonic KX-T7730. Can ant 1 help me
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
Apr 07, 2010 | Panasonic KX-T7730 Corded Phone
How do I change the time on a KX-T7730 phone?
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
Enter the year.
button.
day.
Set the time.
are done.
Mar 29, 2010 | Panasonic KX-T7730 Corded Phone
How to set the clock at a panasonic kx-t7730
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Mar 27, 2010 | Panasonic KX-T7730 Corded Phone
How can I change the time on my KX-T7730 phone
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
6. Press PROGRAM to exit program mode and congratualations - you are done.
Nov 17, 2009 | Panasonic KX-T7730 Corded Phone
How do i program dates and times on the panasonic kx-t7730
081104 2 0300 1
Nov 12, 2009 | Panasonic KX-T7730 Corded Phone
Cant Change the display name
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Jun 27, 2009 | Panasonic KX-T7730 Corded Phone
How can I change the time/date in the LCD Display in KX-7730 THX~
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Jun 18, 2008 | Panasonic KX-T7730 Corded Phone
I am unable to change the time on my phone to reflect the day time savings
You will need to enter programming mode. Here are the directions.
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by setting the switch on the end of a display phone to PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following.
  1. Set switch on end of phone to "PROGRAM" (or push PROGRAM key if you have one)
  2. Dial "0"
  3. Enter year (last 2 digits)
  4. Enter month (01-12)
  5. Enter day (01-31)
  6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.)
  7. Enter Hour (01-12)
  8. Enter Minute (00-59)
  9. Press 0 for AM 1 for PM
  10. Press "AUTO DIAL/STORE" key
  11. Return phone switch to "SET" (or push PROGRAM key if you have one)
Mar 22, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7731 Corded Phone Logo
979 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
