Question about Kitchen Ranges
My stove had a flash and a loud pop, blew the main breaker for the house and now the oven doesn't work. The stove top does, but the start button doesn't for the oven.
  • 67 Answers
Sounds like your oven element has either shorted out or gone to earth. You will need a new element I think.
Posted on Jul 01, 2009
Frigidaire oven trips the breaker w/loud popping spark behind the stove when it is turned on. With breaker reset, the stove was heating up even though it was off. Can it be fixed? I unplugged it.
sounds like someone spilled something down the back of the oven. you wuill have to open the back and trace the mains lead and see were it leads amd if it needs cleaning. rcds trip when water or steam hits the mains.
Apr 25, 2018 | Ovens
Loud pop from Range, stove top still works
The pop was a shorted wire.
The short drew sudden over-amp at breaker.
Amps = heat.
Breaker senses heat and trips before wire to oven is damaged, and before the arcing short can cause a fire.
Was the short at the element?
I don't know, but sounds like the circuit board was damaged.
Of course they are putting electronics inside all appliances today instead of old mechanical dial, because it's cheaper or so much prettier... but new appliances more vulnerable to surge, and other electrical failures. Which is true for all 240V appliances not protected by whole house surge protector.
To test element.
Remove element.
Use a continuity tester across the element connections.
If there is continuity, then the element is probably functional.
Use a multimeter across same element, set multimeter to read ohms.
240 Volt, 3500 watt element should be about 16 ohms.
4500 watt about 12-13 ohms
Volts squared divided by watts = ohms
57,600 divided by 4500 watt = 12.8 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
I would guess that the short fried the circuit board, but there is a also a shorted wire somewhere that is still bare and dangerous while power is ON and you are touching oven or stove, unless 240V breaker is GFCI or arc fault, which probably not. Especially dangerous if you are moving stuff around trying to find problem while power is ON.
Gene
h
Nov 19, 2013 | Frigidaire FEF366 Electric Kitchen Range
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
Stove top and oven doesn't work.
If it is an electric stove it may have tripped one side of the 230 line. Check the house cuircuit breaker panel and find the stove circuit breaker. It will be tied together by a bar or clip. Shut off both breakers completly and reset them back completely. If it is a power problem this should reset the stove.
Dec 01, 2012 | Kitchen Ranges
During cleaning process, blew house breaker. Reset
Seems like you found out the hard way what I wrote about in this tip...
Yuor wiring has been incinerated with the stuff in your oven...
Yes, it can be fixed, depending on what and how much has burnt...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 23, 2010 | Kenmore Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
I was roasting a chicken in my Maytag Cooktop when I heard a loud buzzing and a "pop", all of the power in my house went out. Something had tripped the breaker. My husband reset the breaker but my stove...
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Jun 15, 2009 | Maytag MEC5430BDS Electric Cooktop
Frigidaire ES400 range - oven will not opperate, range will
Me too. Oven was on, big "pop" and breaker went. After re-setting the breaker (and setting the clock on the range), the stove top works fine, and the controller for the oven seems fine, just that neither the top or bottm elements will heat up in the oven. 240 V is getting to the control module, but it is not sending out any juice to the oven elements.
Any fixes out there?
Mar 30, 2009 | Kitchen Ranges
Kitchen Ranges Logo
252 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
