Question about Malber Dryers
Malber WD1000 washer/dryer does not do high speed spin
My Malber WD1000 washer/dryer combination does not perform spin as the last cycle. It's keeps rotating, but not with high speed as before. As a result the clothes are still full of water. Dryer maybe still works, but it is obviously useless to dry clothes with so much water in it. What could be a problem, what part need to be replaced and it is possible to do myself? Is it make financial sence to replace? Thanks
  • edvorkin Jul 01, 2009
    I didn't notice long pause where spin supposed to be. Instead machine perform the same operation as in previous cycle-"permanent press". It is rotating but with low speed.
    How I can identify the part you are talking about - the clutch? Do you have the diagramm
    Genius:
  • 1,689 Answers
A possible clutch issue, please try to check if the weight balance of the clutch for the dryer is properly seated.
we shall try to look for a diagram to show the parts involved in this fault
regards.
Posted on Jul 01, 2009
  • marlon john madrid
    marlon john madrid Jul 01, 2009
    here are the components. i do not have the diagram, but the part are easy to spot.
    On most malber models here is the diagram to see the assembly: Hope this helps,
    regards...
  • 1,056 Answers
This problem is most like cause by a malfunction in the control knob. If you notice a long pause before the unit goes into drying mode then it is the control knob. Control knobs are easily replaced After pulling the plastic knob you will see the screw that holds them. getting access to the back would require opening the top. On this machine they are locked by clip on the front that can be popped up. the rear would have screw. you can order the parts on line. Confirm first that it is bad. The long pause would be where the highs spin would have been.
  • Ronado Panaligan
    Ronado Panaligan Jul 01, 2009
    Okay a final tour of how wshing machines work. The motor in the washing machine can turn in both direction. if made to turn one way a complex gear makes the agitator go back and forth. (thats the plastic thing in the middled of the round tub) When the motor turns the other way complex gear locks up so the whole tub turns thats what happen in the spin cycle. There is either a cluctch, a belt, or a plastic coupling connecting the tub to the gear spline. When they wear out you get a slow moving tub, like what you have. As far as the trouble of fixing it, it is very difficult for a novice. The good thing is the part dont cost that much, usually under 30 bucks. Solution to the problem is change the coupling device to the tub. I is not something an average person can perform. The heat from the dryer may have cause premature wear too, since that is a all in one model.
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Dryer is not working
The air heater and the blower requires to be tested/checked.
Apr 06, 2010 | Malber WD1000 Front Load Washer/Dryer
Does not drain and spin
It sounds as if you have a defective timer control. Try operating the washer on a different cycle, if it spins on these cycles the mechanical workings are fine it's an electrical switching problem in the timer.
Sep 17, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 dryer help...
jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
Jul 21, 2008 | Malber WD1000 Front Load Washer/Dryer
Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
May 25, 2008 | Malber WD1000 Front Load Washer/Dryer
MALBER WD 1000 - UNSPUN HERO
use the rinse cycle on the machine in conjunction with the spin that should solve the problem
Apr 16, 2008 | Malber WD1000 Front Load Washer/Dryer
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
Spin cycle won't get up to speed!?
Might be a control board problem. Contact Malber USA at 1-800-600-8913. They will have replacement part and, if the machine is still under warranty, the part is free.
Jul 08, 2006 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
154 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Tim Whalen
Are you a Malber Dryer Expert? Answer questions, earn points and help others
