Question about Mitsubishi VS-50607 50" Rear Projection Television
I need to replace the main circuit board
I need to replace the main circuit boar.
Coolant from the lamps dripped on to it and shorted it out.
  • 668 Answers
You can see if Mitsubishi Parts Dept. have it available. They would be the only source. There # is 1800-553-7278.
It would be necessary to replace the tubes that had leaked. It would be advisable to replace all three CRT's due to age and there has been a pattern that if one leaked, the others will also.
Hope this helps,
Skyassoc
Posted on Jul 01, 2009
Samsung galaxy note pro 12.2 tablet won't work screen went black and won't turn back on
Either the power supply (battery) has become defective or the main board has a short circuit. The cost of repairs to a main boars is more than a replacement galaxy.
Jan 06, 2015 | Tablets & eReaders
Why yellow display in dukane projector?
it has several possible reason. 1) color wheel 2) sensor board. 3)DMD boar 4) main board.
the most possible reason should be color wheel or sensor board.
at present, what you can do by yourself, trying to clean sensor board, specially clean that small black chip on sensor board. perhaps it is helpful
Jul 13, 2014 | InFocus Lamp Projector Lamp for LP280,...
MY EMERSON TV HAS RED LIGHT BUT WILL NOT POWER ON
The main digital boar should be checked for short circuited components. It will be best to replace it as card basis.
Sep 21, 2012 | Emerson Televison & Video
Replaced lamp
There is some short circuit at the main circuit board. Seek help of any experienced service technician.
Aug 01, 2012 | Samsung HL-P6163W 61" TV
010-327 Fuser On Time Failure RAP
• After the Main Lamp turned On during warm up, the Control Thermistor did not detect
READY temperature within the specified time.
• After the Main Lamp turned On during standby, the Control Thermistor did not detect a
specific temperature within the specified time.
• After the Sub Lamp turned On during standby, the Control Thermistor did not detect a
• After the empty rotation started, the Control Thermistor did not detect the empty rotation
finishing temperature within the specified time.
• After the Main Lamp turned On during printing, the Control Thermistor did not detect a
• After the Sub Lamp turned On during printing, the Control Thermistor did not detect a specific
Initial Actions
Check for paper on the Fuser. The Fuser has no paper wrapped round it.
No)Remove the paper.
Yes)Check the installation of the Fuser Unit. The Fuser Unit is securely installed.
No)Install the Fuser Unit securely.
Yes)Remove the Fuser Unit. Check the conductivity of the contact points of the Thermostat. The
contact points are connected.
No)Replace the Fuser Unit
Yes)Check the resistance of the Main Lamp between P600-3 and P600-7 for an open circuit or a
short circuit . The resistance of the Main Lamp is 100 ohms or lower.
Yes)Check the resistance of the Sub Lamp between P600-1 and P600-7 for an open circuit or a
short circuit . The resistance of the Sub Lamp is 100 ohms or lower.
Yes)Check the resistance of the Control (Center) Thermistor between P600-5 and P600-6 . The resistance is 3k ohms or higher.
Yes)Check the resistance of the Rear Thermistor between P600-2 and P600-4 . The resistance is 3k ohms or higher.
Yes)Check the wire between J410 and J600 for an open circuit or a short circuit . The wire between J410 and J600 conducts with less than a few ohms.
No)Repair the open circuit or short circuit.
Yes)Check the wire between J6 and J600 for an open circuit or a short circuit . The wire between J6 and J600 conducts with less than a few ohms.
Yes)Check the wire between J401 and J523 for an open circuit or a short circuit .The wire between J401 and J523 conducts with less than a few ohms.
Yes)Replace the Fuser Unit . If the problem persists, replace the Power Unit . If the problem persists, replace the MCU PWB .
END
Aug 03, 2011 | Xerox WorkCentre PRO 128 Copier
REPLACED MAIN CONTROL BOARD AND DEFROST HEATER AND THERMOSTAT, WORKED 2 MONTHS NOW ITS NOT DEFROSTING AGAIN
replace the thermistor white bullet with white wires on top evaporator controls defrost circuit to rear boars
Jan 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i unhook the electrical connection from the display to the power wire?
You must watch the flexible cable or connector from display board vs Lower
Board or Main Motor Controller.
Then you must isolate the Main Motor Controller from Power Supply coming from coil or Transformer. +Pull out the fuse and turn Off.
See the block diagram that I did as people like you for yourself take carefully.
11_29_2011_4_39_37_pm.gifFinally to make short circuit in Boar or component. sincerely.
E.CUADRA
MANAGUA, NICARAGUA.C.A
Nov 18, 2010 | Nordic Track NordicTrack A2750 PRO...
Minolta's DiALTA Color Series CF3102/2002 Service code 1220
Image control board not talking to a main control board, this mite take a while and mite quite costly if you can even fine the board if required to be replaced. First to reset open close front door, if the code comes back, you will have to begin by unplugging machine and removing each connector on each big printed circuit board check each connector on the boars for a bend pin the reseat each connector, next replace boards try site below, could try firm ware update via Konica Minolta Dealer ship they might have access to the secure server for firmware,
Used PCB Circuit Boards for Copiers PCB Assembly Circuit Board Repair
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 23, 2008 | Minolta Office Equipment & Supplies
Power up on tv
Usually, that symptom indicates CRT coolant leakage on the
circuit board below the drip.....creates a short circuit,which
turns off set.....Have it examined by a Mits tech to be sure......T.
Dec 04, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-60705 red lamp replacement
The part you are describing is actually the red picture tube, not a lamp. The tube will come dry and you will need to disassemble the lens assembly on the old tube, drain the coolant (antifreeze), reassemble the parts and seal on the new picture tube, fill with fresh coolant, install the new tube, reconnect all wires including the dangerous high voltage lead, then realign the yoke and entire convergence circuits. This is not something that should be attempted by anyone without experience. If you try it yourself and the seal is not working perfectly, the coolant will drip down on your main boards and the set will be ruined. If you slip while lowering the new tube in the chassis there is a good chance you will crack the tube's neck, and that tube will be useless too.
Jul 30, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
