Question about Polaroid CSA-00301S: 1.3 Megapixel Video Camera Camcorder
CAMERA SHUTS DOWN WHEN SD CARD INSERTED
The camera runs fine until i load the sd card into it. the amera takes a little longer to come on and then it turns off. i have twi different ones and they both are doing the same thing.
  • 110 Answers
SOURCE: how do you get rid of card locked message on Polaroid T830?
SD cards have a tiny slide tab on the edge of the card.
This is used to lock the card, so you can't alter the contents.
Slide the tab to unlock the card.
Posted on Apr 04, 2008
kenshin99
  • 89 Answers
SOURCE: Card error
Hi!
I wish what I'll be saying will resolve the problem. Unfortunately, your camera can only support up to 1GB of SD card. That's the reason why the 4GB card is not working.
Here's a screenshot of the details regarding your Polaroid camera.
I hope that helps.
Good luck and have a nice day!
Posted on Nov 27, 2008
jcdill
  • 121 Answers
SOURCE: Pictures do not show up on SD card
Have you successfully used this card in this camera before? If not, you may have a new card that is too large for this camera to use, not all cameras can use the newer large cards. If you have successfully used this card in the camera before, you need to reformat it IN THE CAMERA to make sure the file structure is correct for this camera. When you reformat a card all the data on the card is lost, so be sure you have copies of all the photos backed up on your computer before you reformat the card!
Posted on Dec 12, 2008
robmcd27
  • 423 Answers
SOURCE: camera does not recognize memory card
Did you format your memory card before you tried to use it? Format your SD card in the camera first and see if you still have the problem. Also, check to make sure the switch on the card is not in the locked position.
Rob
Posted on Mar 03, 2009
SOURCE: Can't take Picture
Some SD Cards have a physical lock on the side of the Card. Try taking the card out of the camera and look for a small white piece of plastic that you can slide on the side of the card. You may need to slide it to the unlocked position for the camera to be able to write to the card.
Posted on Apr 14, 2009
Why does it say that there is no external storage for my camera? It won't let me use the camera.
there might b sd card mounting problem.. try using ur sd card in any other device and see if it works.. if it does not, there is little u can do. apps are avaiable on android market to resolve sd card problems and revover data. however, if it works fine in other device and only shows problem wid the cam, it might b that the device does not support the sd card, ie. the storage capacity is too large to be mounted by the device-.
Dec 04, 2014 | Cameras
My camera wont read memory cards anymore. It was working just fine, then the next picture I tried taking it said "memory card error" and the memory card works in other cameras, and my camera turns on and I...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 29, 2010 | Canon PowerShot A610 Digital Camera
Vivitar 5399 not reading memory card. Originally had a 4GB card and that worked fine, then all of a sudden the camera wouldn't read the memory card. Card is fine in other cameras. Just switched to a...
Hello
Kind regards
Andrea
Aug 28, 2010 | Vivitar Vivacam 5399 Digital Camera
I have a canon SD100 i put a new memory card in it it says memory card error i try to reformat it it says E50 left hand bottom corner then shuts off
Hello
Kind regards
Andrea
Aug 14, 2010 | Cameras
New camera, new 2gb memory card saying memory card full? Tried formatting still not working, also checked card not locked.
Hello
If it is a new camera , you should take it in for a exchange.
Kind regards
Andrea
May 06, 2010 | Vivitar Vivicam 8225 Digital Camera
Camera says card is locked in the unlocked position. The internal memory works fine.
Hello
Kind regards
Andrea
Jan 02, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
My 3.2 bean camera uses a sd card and i dropped it and now it says card locked when i try to take a picture or video . I tried to unlock and lock the sd card but it still comes up
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
Kind regards
Andrea
Oct 25, 2009 | Argus Bean A0570 Digital Camera
Protected Card
Hello
Kind regards
Andrea
Jul 11, 2009 | Fuji FinePix A201 Digital Camera
Locked Memory Card
Hello
Kind regards
Andrea
Jul 11, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
SD CARD LOCKED
Hello
Kind regards
Andrea
Dec 16, 2007 | Pentax Optio W10 Digital Camera
Polaroid CSA-00301S: 1.3 Megapixel Video Camera  Camcorder Logo
76 people viewed this question
Top Polaroid Video Cameras Experts
Eric Sutherland
Rochell Cruz
Tony Parsons
Tony Parsons
Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
