"Sharp" brand tv suddenly has wierd reddish tint on every channel, it's like the color suddenly turned WAY up. Went thru menu screen, nothing helped.
    Brigadier General:
  • 8,619 Answers
Hi
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set. If this is not the case then check the convergence IC as it could be bad and needs replacement.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 01, 2009
My toshiba 61h71 has a reddish tint to it. Turned it off one night and it looked fine, next morning it got this reddish tint. Tried resetting the convergence but that didn't change the situation at all....
A Reddish tint means that the Green signal is missing. Does the on screen menu look normal? If so, this points to the signal source. The fact that this happend suddenly, I would check your cables first.
Using YUV?
If the TV's Menu also looks reddish then there is an internal problem with the display.
Good luck
Dec 30, 2009 | Toshiba 61H71 61" Rear Projection...
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
Apr 11, 2009 | Dynex DX-LCD37 TV
Green tint
Check 3.58 MHz color oscillator,, little metal can near large ic,
Also check color output transistors or any loose connections in the output stage
Jan 19, 2009 | Symphonic ST420FF 20" TV
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Projection tv has a reddish tint on the screen and appears to look hazy and flushed. Flesh tones have a red/orange hue.
first try adjusting the color-tint on the menu if this does not solves the problem you have a failing proyector and has to be replaced
Apr 03, 2008 | Televison & Video
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Aug 25, 2007 | Sharp 25L-S100 25" TV
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
