Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Trouble code i am getting a code 63 when i check it on the tack. it says that it is a historic code but I cant seem to find out what it really means. the bike that i have is a. It is EFI.
  • 40 Answers
If it 0603- its loss of ecm; maybe key was on when ecm was disconnected etc; if its historic clear it, if it comes back look into it; if it doesn't your good; maybe last service tech didn't clear codes after work etc
Posted on Jul 07, 2009
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
How to read check engine codes
The engine light lights up when you turn the ignition switch on, then goes off. After four seconds, if it comes on again and stays on, there is a present fault code. When it is an historical fault code, it comes on with ignition and goes off then comes on and goes off again. I believe in like 4 second intervals. An historical code will not be removed until a cycle of 50 ignition on/of intervals has passed. In other words, the engine light will continue to light two times when ignition switch is turned on, after 50 on/off cycles have passed the historical codes will no longer affect the engine light when starting.
If you will hold the odometer button on the side of the console down, and turn the ignition on and off, three times I think, waiting for the fuel pump to stop before turning the ignition switch to the off position, and one second until you turn it on again, the third time holding the odometer button down until the engine light begins to blink it will begin to blink in a fast sequence showing the fault codes will follow.
First indication of fault code display is rapidly blinking engine light. After that count the number of times the engine light lights up. There will be a brief pause between digits. If there are multiple codes stored, the rapid blinking will separate each. Once the fault codes begin to repeat, you have gone through all stored codes.
Tips: Have a pencil and paper ready.
Maybe ask a friend to help out. Sometimes a second pair of eyes can be good.
Go through a couple of cycles, so that you are sure you haven't missed any codes.
Method #2:
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector. Other models will be under the seat.
2. To activate the diagnostic feature,follow these steps.
a. Create diagnostic test wire or use a female spade clip which will bridge the two terminals perfectly.
b. Install diagnostic test wire/clip across Terminals 1 and 2 on the data link connector, they are marked.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diagnostics manual you're not going to know what they mean.
After retrieving codes, repost the codes for meaning (too many codes to type them all here)
Mar 05, 2014 | 2000 Harley Davidson FXST Softail Standard
2003 harley softail will not start
Did you pull any error codes (Diagnostic Trouble Codes)?
21 Current 12 MAP sensoropen/low
22 Current 12 MAP sensorhigh
25 Current 15 IAT sensorvoltage low
26 Current 15 IAT sensoropen/high
27 Current 24 Front ignition coilopen/low
29 Current 24 Front ignition coilhigh/shorted
30 Current 25 Rear ignition coilhigh/shorted
56 Current 41 Ignition switchopen/low
74 Historic 12 MAP sensorhigh
77 Historic 15 IAT sensorvoltage low
78 Historic 15 IAT sensoropen/high
79 Historic 24 Front ignition coilopen/low
80 Historic 25 Rear ignition coilopen/low
81 Historic 24 Front ignition coilhigh/shorted
82 Historic 25 Rear ignition coilhigh/shorted
Dec 28, 2013 | 2003 Harley Davidson FXST Softail Standard
Check engine light on, code scanner does not show anything.
The Check Engine Light is historically ambiguous it can mean bad trouble,or a speck of dust on a sensor wire...Usually not a problem..Worst things the ever put in cars,,If it runs ok,chances are its just a fluke.
Nov 01, 2013 | Cars & Trucks
What does daignostic code dia9 mean?
The IM (instrument module) is capableicon1.png of
displaying DTC's (diagnostic trouble codes).
1- Ignition off
2- push odometer reset
button in & hold. Make sure run switch is on.
3- turn
ignition to run and release button (you will see P, S &C displayed)
4- each letter represents an area of diagnostics... the one that
is flashing is the one you are going to check. To move from one letter to the
next, you push the button one time. (from P to S to C and back to P, etc.)
5- to get DTC within an area, you push and hold the button in
for 5 seconds and if there are any, it will be displayed... you can release the
button. As you push the button again, other codes will appear if they are there.
If there are not any the wordicon1.png 'none'
appears.
6- Record the codes.
7- To
determine if a code is current or historic, you clear the codes while being
displayed by pushing in and holding the button until 'clear' comes up. Turn off
the ignition... then crank or restart the bikeicon1.png... turn
off, and then repeat the code process. If a code is there now, its current... if
not, it was historic.
Codes
Aug 16, 2013 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Retrieve codes for 2003 road king
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
10 43 Loss of power train security status
Apr 11, 2013 | 2003 Harley Davidson FLHRCI Road King...
I'm having trouble with tack and speed guage when
Seems like you need to replace the speed sensor
Nov 29, 2012 | Cars & Trucks
My rpm's raise and drop at a stop and engine stalls when i turn ac off
We need to know the model, year, engine size, and the actual trouble code to really help you; but I provide some generic tips at the link below. Do not replace the sensor until the problem is properly diagnosed. O2 sensors rarely cause stalling. Get the computer scanned and ask them to find any historical or pending trouble codes. Write them down and post them here.
Do It Yourself Diagnosis and Repair
Aug 23, 2017 | Cars & Trucks
I have an 1998 RoadKing Classic i need to reset the code do1clr how do i reset it
If this is a historical code, meaning one that has registered once and not a current problem, you can clear the code by disconnecting the battery for about 30 minutes. Doing this will clear the historical codes.
Aug 01, 2010 | 2006 Harley Davidson FLHR Road king
I have a 02 ultra the trouble codes are flashing
This is from www.aimag.com/.../4959-diagnostic-trouble-codes-2.html Not good news. Here is what I found for older Delphi FI models 2000-2003.
63 Historic 14 Loss of all ECM serial data (state of health)
You should buy a Clymer manual for your bike, unless you have the manual from the dealer and check that. Hope this helps.
Oct 05, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
Lands Phones Logo
114 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
