Question about Maytag Neptune MDE5500AY Electric Dryer
Inside the drum there are three paddles and one has worked it's way lose. What is the name of this part and is it something that will snap in place easily, or must I get professional help installing?
  • kraby1 Jul 03, 2009
    Shane, Thanks for a fast, informative response. I appreciate your help!
    Sniper:
  • 68 Answers
It is called a baffle. two screws hold each in place, and is is common for them to gradually loosen. it is also easy to tighten them back. open the door, there are 4 screws on each side inside door frame, remove them. then pull the front panel from the sides towad you, the pannel will come foward then lift up and set panel aside. there is 1 screw on each side holding the top down, remove them then top hinges up. you will be able to see the drum and as you turn it you can tighten the screws to all 3 baffles, then re-assemble. good luck. shane
Posted on Jul 02, 2009
Hotpoint wmdp62 drum paddles replaced and wont stay in
I would need to see what you did to understand this problem. I suggest you call a technician out to inspect the problem.
Jul 20, 2017 | Washing Machines
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
I HAVE A MAYTAG NEPTUNE GAS DRYER MODEL 3MDE3000AYE. ONE OF THE THREE PADDLES INSIDE THE DRUM CAME OFF. I AM TRYING TO REATTACH IT TO THE DRUM, BUT THE SCREWS HOLDING THE PADDLE ARE INSIDE THE DRUM.
unplug the dryer,open the door,remove the two screws holding the door on and remove the other two screws opposite them,take off the door and pull the front panel off,spin the drum until the baffle you are trying to repair is in the bottom right hand corner and you can get at it like that
Mar 13, 2010 | Dryers
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Why do sheets ball up and not get dry
Make sure there is a paddle inside the drum, the paddle is a baffle plate on the inside of the drum that helps to avoid this.
Aug 24, 2009 | Asko Dryers
Washing Machine Paddles
I have a bwm129 and two paddles have broken of I can get two more paddles and they look like they just slide into place but should I open the back up to see if there are any of the broken retaining hooks behind the if so how do I do this?
Jul 02, 2009 | Washing Machines
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Maytag Neptune MDE5500AY Electric Dryer Logo
150 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
