Question about Aiwa Audio Players & Recorders
Right i have an aiwa mx-n9 + mx-n7 systems mx-n9 keeps
Right i have an mx-n9 + mx-n7 systems mx-n9 keeps burning out heat fans?, which is the better model?
  • 1,056 Answers
These little fans are driven by fluctuating currents not DC current. It is a problem with the circuitry the drive it. The current are pulse width modulated, which is how the speed of the fan is controlled.
Posted on Jul 01, 2009
I need cobination codig for AIWA MX-NH1100, to programing remot control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Apr 10, 2016 | Aiwa Televison & Video
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
My gateway mx laptop gets so hot you can fry an egg on it and the fan runs all the time and shuts down when its hit its hottest what can be done about this i have to shut it off or the fan will still...
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Mar 26, 2011 | Gateway Computers & Internet
I keep getting "check Fan #1" on my Samsung HL-T5087SA DLP TV. I vacuumed it and it is still doing it. Anybody know how to fix it. TV goes off by itself after a few minutes.
you need to test the fan if it is working or not or better replace the fan with a new one.there must be shortage of voltage coming from the fan thats why the unit turn itself off.over heating of components near the fan might be the cause because your fan is malfuntioning thats why you got a keep getting the message check the fan better replace it..
Jun 26, 2010 | Samsung Televison & Video
Copied CDs won't play with my Aiwa LCX 350 shelf system. It will spin for a bit, then stop. I've tried every method ... with or without remote, start/stop, etc. This doesn't happen with any retail CD. Only...
It sounds like it's not reading the CD. 2 things to try, neither of which are guaranteed to work:
1) Try changing the brand/colour of your recordable CD.  Some machines read different colours/brands better than others; particularly older CD players.  If the ones you have are all light-coloured, try burning a couple of dark-coloured CDs and see if that helps
OR:
2) It could be the speed at which you're recording.  Try burning a CD at 1x speed and see if that helps.
May 26, 2010 | Aiwa Audio Players & Recorders
Processor heats up while processing heavy graphics
The only way to keep it cool is a bigger heat sink or more airflow.
We have mounted fans into the top of the side panel of a PC to draw air out of the chassis which seems to do the trick
Get a QMax cutter and put some holes in the lower half of the right hand panel
Cover the holes with stainless steel mesh glued on with a hot glue gun
That way you create a chimney effect causing cooler air to be drawn in at the bottom and the hot stuff out of the top
If the fans can be mounted above the level of the processor then you have the optimum
Jun 18, 2009 | ASUS P5VDC-MX Motherboard
How do I get started with loading pictures
You can download the manual and read the FAQ on the manufacturer's web site at
http://www.nextar.com/frontend/proddetail.asp?pn=N7-202&co=10000328
Dec 08, 2008 | Nextar N7 - 7 Digital Photo Frame with...
552 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
