Question about GE GSS25SGMBS Side by Side Refrigerator
How to install a defrost timer on a GE side-by-side refrigerator
I know where the defrost timer is located but I am not sure how to remove other parts without damaging something else.
  • Mike Smith
    Mike Smith May 11, 2010
    Brand and model number needed to help .
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 1073 Answers
SOURCE: Problem auto defrost refrigerator
loaded question any COULD be bad a volt ohm meter will tell you whitch one is bad
if this is a ge sxs i would check the defrost heater first
Posted on Jun 24, 2008
SOURCE: red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Posted on Sep 10, 2008
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
Posted on Dec 27, 2008
  • 306 Answers
SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Posted on Jan 01, 2009
FREEZER SIDE FREEZES UP REFRIGERATOR SIDE IS WARM
Hi I t seems like the Defrost timer is not working or is stuck. It could also be the defroster coil but probably not. The timer is located in the front of the refer where the toe kick is . remove the toe kick, check for a square or rectangle box with a big plug on the back. that is probably it. Check with the appliance zone online you need the Mod. # for the parts blow up. look for the defrost timer on the print. that will also show where it is located with a part #. you can then price it out . It is not too hard to install be sure to unplug it before removing any wiring.
Good Luck, Bill
Jan 07, 2018 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor and fan stop working
There is a possibility that the defrost timer turned the compressor and fans off and stuck in the defrost lobe of the defrost timer. I want you to try turning the defrost timer slowly clockwise. The defrost timer is in location 257 behind the control panel inside the fresh food compartment. Here is a photo of the parts location HERE
If doing this causes the refrigerator to work again then replace the=> WR9X489 Defrost Timer
If this does not work I want you to try something else so let me know what happens Thanks
Sea Breeze
Apr 05, 2013 | GE Profile Performance 25.2 cu. ft....
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
How to locate and replace defrost timer on GE GSS23KGSA WW
Yes the GSS23KGSAWW defrost is controlled by the WR55X10942
motherboard. What is happening that you would ask about a defrost timer? Let me know if you have questions, Thanks Sea Breeze
GSS23KGSAWW Service Manual
Nov 19, 2012 | GE GSS23KGS Side by Side Refrigerator
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
Won,t get cold freezer side not freezing it is a ge side by side . ice is present at the back of freezer side
The problem is most likely the defrost heater element(s) and/or the defrost timer. The defrost heater element(s) are located with the evaporator core behind the access panel inside of the freezer, and can be removed, tested with an ohm meter, (any reading other than infinity would most likely mean the heater element is functional) and replaced if necessary. The defrost timer can be located inside of the refrigerator, or outside of the refrigerator behind the front kick panel, or behind the rear access cover on the back of the refrigerator.
Usually if the evaporator core is freezing up and not allowing air to flow through the evaporator core, (necessary for the system to function properly) then the defrost timer is most likely working and the defrost heater element(s) would most likely be at fault.
Always place a towel on the bottom of the freezer and use a blow dryer to defrost the evaporator core and never use any sharp or hard objects to pick away the ice or the evaporator core can be damaged and the refrigerant will be leak from the system.
I have included some images to help assist you including an image of a defrost timer that is located inside of the refrigerator, and a new defrost heater element or defrost timer can be purchased from an appliance parts distributor.
Let me know if you require any further assistance.
Jul 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
Freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Jun 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost Timer
Hi: It is your defrost heater most likely. If not the defrost timer. The heater is in the bottom of your freezer behind the metal panel. Next time you defrost it remove the panel and inspect it. It's a glass tube with a metal coil (filament) running through it. If the coil is broken replace it. If not look into a defrost timer. The parts will be shown on sears.com with a diagram. I hope this helps. Jeff
Jun 08, 2009 | GE GSH25SGPSS Side by Side Refrigerator
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
228 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
