Question about RCA HD52W58 52" TV
Prior to this, screen size changed at will.....
Same problem, prior to the flashing light the screen size would change at random, tiny to huge, to big for the screen, shop told me most likely a CPU 500bucks...... could a capacitor cause this?
All you have to do is go in the menu and go to picture...once you are in there turn "Auto format" off.
Posted on Jul 04, 2009
HOW DO YOU CHANGE FONT SIZE
Change the font size on the computer prior to printing.
Jun 10, 2014 | Dymo LetraTAG Thermal Label Printer
91 firebird new battery just wont start
I agree, more information would be helpful and engine size too. Also, why did you replace the battery and what was it doing or not doing just prior to the battery change?
Jun 03, 2014 | 1991 Pontiac Firebird
I have replaced the ribbon twice now but the print still comes out very light
I'm having the same problem. This is my second Sharp EL-2630PIII calculator and the first one did not have this problem (prior job). I can change the ribbon and the print is still so light I cannot scan it as part of my work papers... which is a huge problem as an accountant.
May 21, 2014 | Sharp EL-2630PII Calculator
Input signal out of range
Hello
Boot the computer into SAFE MODE. Go to CONTROL PANEL - DISPLAY PROPERTIES. Change the screen resolution to a common size - like 800x600 or 1024*768 and save the settings. Reboot the computer.
Everything on the screen will be very large but you should be able to see the desktop and make additional changes. Go to CONTROL PANEL and DISPLAY PROPERTIES again, and change the screen resolution and click APPLY. This will change the resolution to the new settings and will give you the opportunity to revert back to the old setting if it does not work.
Once you hit APPLY - the screen will change. If you can see the screen, you will see the option to ACCEPT the changes or to REVERT back to the prior setting. If you do not choose anything, the system will revert to the prior setting automatically - typically in about 15 seconds.
Make changes to the screen until it appears as you want it, click ACCPET when you find the one you like.
Feb 22, 2012 | HEWLETT-PACKARD Slimline Desktop / AMD...
My computerr screen is too little how do i ajust
by going into start> control panel > and display you can adjust the resolution of your screen here is a list of the correct sizes for the screens Please let me know the outcome of this, if it says frequency out of range then youwill need to download the drivers for your graphics card before doing this.
14" 15" 17" 19" 21" 640x480 BEST GOOD TOO BIG HUGE TERRIBLE 800x600 GOOD BEST GOOD TOO BIG HUGE 1024x768 TOO SMALL GOOD BEST GOOD STILL GOOD 1280x1024 TINY TOO SMALL GOOD BEST GOOD 1600x1200 TERRIBLE TINY TOO SMALL GOOD BEST
Jul 06, 2011 | Computers & Internet
2003 ford f 150 4.6 v8 and the idle went from smooth to rough also sputters and sluggish while driving check engine light is flashing.
have the vehicle scanned for error codes at autozone, its free. Post codes for more help....These engines have issues with the COPs (ignition coils-over-plugs) failing prior to 80k miles. When they fail typical problems are: Sputtering under load/acceleration, rough idle, random misfires, random stalling, light or heavy jerking under load (usually at 15-35mph and 45-65mph)..hopefully this helps!!
Apr 28, 2010 | 2003 Ford F150 Regular Cab
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
1997 honda passport noisy lifters
You could try running a flush chemical in the engine oil just prior to changing the oil, and then using synthetic oil. This may free up the little tiny valve in the lifters and reduce the noise. At the very least, it will help prolong their life. It is a very big expensive job to change these because they are generally replaced as a set and they are not cheap, but replacement is often the only true fix.
Mar 13, 2009 | 1997 Honda Passport
Oxygen sensor
Sometimes you'll find Chrysler dealer parts cheaper or as cheap as aftermarket, so make sure you price it through them too. Should only take a few minutes to change so I can't see labor being too much. I'd just do the one for now, like I said, a few minutes labor, so if it other needs doing later, no big deal unless you want to save the extra diagnostic charge, if there is one.
Oct 15, 2008 | 2004 Dodge Grand Caravan
RCA HD52W58 52" TV Logo
124 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
