Question about Mitsubishi WD-65731 65" HDTV
I forgot to reset the lamp hours back to zero after replacing lamp and a week later the red light is on again. Please Help!
  • Terry Huckaby Jun 23, 2013
    How do you reset the lamp hours?
How to reset the samsung lcd projector,model:SP-250m lamp hours
Posted on Feb 19, 2011
Have just replaced the lamp on my m300w projector and I van not get it back on it still has the Red lamp light flashing on it will not turn on any idea please
Here is the User Manual in case you need it:
http://www.necdisplay.com/documents/UserManuals/Mseries_UserManual.pdf
Did you use a NEC NP16LP lamp (M350X/M300W/M300XS/M260WS)?
If you continued to use the projector for 100 hours after the lamp reached the end of its lifr, the projector cannot turn on and the menu is not displayed. If this happens, press the HELP button on the remote control for 10 seconds to reset the lamp clock back to zero. When the lamp time is reset to zero, the LAMP indicator goes out.
Dec 17, 2014 | Office Equipment & Supplies
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
Sony grand wega 3lcd light is flashing red 3 times
Three flashes is lamp cover/lamp position error, it means the lamp cover is not set right, or the lamp is not in the right position. There are two micro switches to detect the lamp position, and lamp cover. Please reset the lamp and the lamp cover (door).
Aug 01, 2017 | Sony Televison & Video
I replaced the projector lamp and still no light what am i missing. all i get is a solid red lamp indicator and a orange power indicator.
hi,
Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
Feb 10, 2011 | NEC VT465 Multimedia Projector
Look my problem is that i have a sharp 56dr650 i replaced the lam p and it worked for 3 days then i turned it back on and nothing happems. No backlight not sound no nothing. The power light comes on...
within the 3 days of replacing your lamp to when it stopped working, did you open the access panel for the lamp again? If you did, the interlock switch might not have engaged when you put the panel back on. Make sure the switch is in the O position, then try powering it up.
Nov 05, 2010 | Sharp 56DR650 56" Rear Projection HDTV
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Reset lamp hours on sony grand wega
    hello
    1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
    2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
    3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
    shaun
    Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Lamp hour reset
    I don't thing that because you were not reset the time lamp used now your LCD projector stop function
    What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
    As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
    I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
    Cheers
    Dec 24, 2008 | Office Equipment & Supplies
    Mitsubishi WD-65731 65" HDTV Logo
    638 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
