Question about Generac Guardian 200 Amp Transfer Switch with Service Disconnect NEMA 3R
Generac 4456 does not start on power loss
I have Generac 4456-0 generator that is 5-6 years old. It has the GT-990 engine. It was installed at my old house. When I moved (about 2 years ago) I brought it to the new house. I purchased a new 16 circuit transfer switch. I made the appropriate control wiring changes and removed the external battery charger from the transfer switch as mine has the internal. I placed a new battery in the unit and changed it from LP back to natural. Checked the oil hit the "manual" on the 3 position switch and it fired up. I wired the transfer switch. Upon placing the switch in "auto" and shutting the power off the generator did not start. I left the power off and went out to the generator and manually started it. Once it was running the transfer switch through automatically and was supplying power (although frequency was a little low 58.5 hz but I can adjust). When I restored normal power the transfer switch transfered back to normal power (I did not time it as I walked back out to the generator to shut it down). I checked all the connections at the generator and things seem okay (N1 & N2) have 238-240V so the normal power sense has made it to the generator. I tried placing the unit on "auto" and holding down the test button for an extended period of time (almost a minute) and nothing happened. So I am looking for some advise on what to check next or if somebody says "oh it's this". Thanks Dave
  • frizzellfami Jul 10, 2009
    Thanks for the help. I was able to find a technical trouble shooting manual on the web that was a great help. I ordered a new control board because I have heard that they are notorious for going bad. In the process of following the steps I tested the auto-off-manual switch and it was found to be bad! Replaced the bad switch, installed the new control board, changed the oil and filters. Started fine and transfered. Adjusted voltage and Frequency. It is working great. Now just waiting for a power failure!
    Thanks
    Dave
  • 26 Answers
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Posted on Jul 09, 2009
What is the headbolt torque spec of the generac gardian gt-990 engine
Follow the link in additional comments to the Google search results page and slect the service emanual for the generator at top of page, it is a large download so be patient.
Oct 21, 2016 | Electrical Supplies
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
I need a owners manual
Owner's Manual - Northern Tool + Equipment
www.northerntool.com/.../manuals/166114.p...
Northern Tool + EquipmentOtherwise, back feed from the generator into the power grid could kill utility workers...... information, always refer to the engine Owner's Manual furnished with thegenerator. .... (a) Hard-starting motors require 3-5 times the rated running watts.
Online Product Support - Generac Power Systems, Inc.
www.generac.com/.../product-support-lookup
Generac Power SystemsOr how about a new hose for your pressure washer? Shop and buy genuine Generacparts and accessories for your home backup generator, portable generator ...
[PDF]Owner's Manual - Home Depot
www.homedepot.com/.../66508163-2ff4-4048-9162-0...
The Home DepotThis manual contains important information that you need to know and understand in ...Power Output. This generator is not designed to power sensitive electronic equipment... Do not touch electrically energized parts of the generator and.
[PDF]Owner's Manual - Smarter Tools
Jan 21, 2016 | Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
I have a 16kW Generac Guardian Generator with a 200 amp house service RTS panel (installed 2007). Last night the power went out and the generator started but the unit did not switch to use generator
The problem with the repair service is another matter. Emergency generator and it's switch gear are there for emergency purposes. It has to be exercised periodically. The switch gear should have a toggle switch to simulate a power outage. the switch cuts power to the sensor sensing power from the utility company. This tells the switch gear that power was lost, start the engine and switch over to generator power. Run for a period where engine reached running temperature and switch back to stand by to shut down. Do this periodically, and be grateful the event was not a disaster. Think of your back up electrical system as the spare tire of your car and similar equipment and enjoy your investment. Good people brings you happiness, bad people brings you experience !.
Nov 11, 2014 | Generac Guardian Electrical Supplies
Generac troubleshooting
please send me more info about this generator I need a model number is this a natural gas or propane I have a neighbor that just had one installed I might be able to get some info from him to help you
Aug 30, 2014 | Generac 17 Kw Air-Cooled Standby Generator...
Generator is dragging when load is applied
if it drages less or not at all during night that means air fuel mix screw on the carb needs to adjust for proper intake of oxygen in the cumbustion chamber but you have to set it two times on load and no load condition till the engine runs smooth another reason is when the engine is dragging and there is smoke in the exoust that means engine oil is going up in the cylinder head which results in dragging and loss of power for that matter piston rings has to be changed but firstly check the first one
Aug 15, 2012 | Generac Power Systems Generac 0057890 3250...
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
Generac Guardian 200 Amp Transfer Switch with Service Disconnect NEMA 3R Logo
653 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
