Question about GE 24 in. GLD6200L Built-in Dishwasher
My GE dishwasher is leaking water from the bottom of the machine
I have 3 and a half years old GE dishwasher, GHDA450 series. It is leaking water from the bottom few seconds after I set it on. Before I noticed the water coming out from the machine I smelled like rubber burning and after that I saw the water coming out from the bottom to the front of the washer.
  • 58 Answers
First check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Posted on Jul 01, 2009
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
MIELE G646 Wonderful machine, but now 10 years old ! I noticed a small leak on the floor which appeared to be coming from the bottom of the door, on both sides. This was noticed after a programmed wash...
Clean gasket with clorox to remove any funk, and apply vasoline to gasket to improve seal. If you still have water leaking, you will need to replace the seal on the dishwasher. Should be able to order from an appliance parts dealer, or they may provide a univeral gasket that would fit your machine.
Jan 07, 2012 | Dishwashers
Dishwasher is not draining properly. 1 year old
Check that there is nothing clogging the inlet to the pump below the strainer at the bottom of the machine and slowing down water getting to the pump. This will mean stripping down much of the bottom of the machine, but is unavoidable. Also check that the drain line is not blocked. If there are no problems there, the change over valve may be leaking and returning some of the water to the machine instead of draining it out.
Feb 01, 2011 | GE Adora GHDA656LSS Stainless Steel...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
I have ge dishwasher thats 3 years old and I'm having problems with it leaking from the bottom of the door. I replaced the seal once but I can't tell what else the problem could be. Any suggestions?
it could be overfilling. check the overflow float inside. if it is stuck down, the water level will get to high. the seal is not meant to be under water. it just stops splashing water. if it moves freely, it is okay.
Oct 26, 2009 | Dishwashers
My Bunn coffee pot leaks water theres always a puddle of water under the pot.coffee pot is over half full
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Sep 13, 2009 | Bunn NHB Coffee Maker
Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Suds and water staying in Whirlpool Quiet Partner III
I believe you may be over sudsing, Try a few cycles with vinegar and no soap. Do not use dishwashing soap at any time ever. See if the vinegar trick helps...helijm
Dec 01, 2007 | Dishwashers
GE 24 in. GLD6200L Built-in Dishwasher Logo
564 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
