Question about Sony CDX-444RF 10-Disc CD Changer
Cd changer not working at all.
Last time i used it was before replacing my battery. i pressed the reset button like the maunual says, but nothing cant eject or turn on. checked the fuses to the changer they are good and i cant find any blown fuse anywhere....please help.
sony cdx-444rf
  • dsv11 Jul 01, 2009
    thanks for your help...i do have power to the wires. the controler up front doesn't turn on though, is it or maybe there's something else i can do ?
    President:
  • Sony Master
  • 1,114 Answers
You need to put a meter on the power wires to make sure you are getting power. If you still have a problem, post a comment and I'll help you dig further. Hope this helps
Posted on Jul 01, 2009
My battery recently died and I had to get a new battery. Upon replacement of the new battery, by CD player stopped working. It is an 6 disc unit integrated with the AF/FM and is original equipment. When I...
I am very sorry to read your problem, but I'm afraid the unit is 'non-repairable'. I've seen this on more than 2 dozen Hyundai Sonata's. Replacing the battery had nothing to do with it... it's when the original/other battery went dead, the internal (already weakend/aged) circuits went permanently to sleep and will probably never wake up again. The 'reset' the dealer tried was merely removing power to the unit. In a sense, when your battery went dead and you replaced it, you also did a 'reset'.. but it wouldn't come back completely. The CD changer has known problems. The noise you hear is the CD Changer trying to 'boot up' so to speak. It's programmed to complete an internal 'Set Up' and "identification' of any CD's which may already be there -- it just quit working. Its Electronics have malfunctioned - basically the CD changer circuit board.
Mar 23, 2011 | 2006 Hyundai Sonata
A cd is wedged in unit. can not remove cd changer
First press and hold Track-Up and Mode buttons at same time on unit for three seconds to reset disc player, then check if cd get release.
In some cases, performing a reset on the MCD6 may resolve your problem. First try resetting the MCD6 player by pressing the TRACK UP and POWER buttons at the same time. If that does not work, remove the plastic front cover by pulling straight out and press the RESET button below the keypad. If your MCD6 player still does not operate, please take off cover from cd player and try to manually release wedged cd in unit.
If loading gears worn out then nothing will help to fix the unit, please contact local repair shop or M&S Systems at (214).358-3 196
Hope these info will help you.
Let me know if you have any question.
Thanks.
Nov 03, 2010 | M&S Systems MCD-6 6-Disc CD Changer
When i want to change from radio to cd function on my head unit nothing happens, the radio works i think it happened when my battery was flat and had to get aa out to restart me, cant be the code as radio...
try pressing the reset switch or disconnecting power to the radio for a few minutes. sometimes jumping the battery sends a voltage spike to the radio and locks up the microprocessor.
Feb 25, 2010 | Alpine CHM-S630 6-Disc CD Changer
CD Changer doesn't work after changing battery on Jeep Liberty 20
The CD changer probably failed to establish it's link to the head unit when you put the new battery in.
Since you've already tried the clear button, I'd suggest unplugging the IP-BUS cable (black cable) from the back of the changer, wait a minute (literally, 60 seconds) and plug it back in.
Jul 20, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Not working error 50 and 70
Clean the unit if possible. does the cartridge eject? if so, load it with a cd player cleaner, preferrably one that uses a cleaning solution. put it in tray slot 1. load and wait. try this a few times then try a good disc, one that is not scratched up. changers are hard on cd's. If it's still not working, below the cartridge slot there should be an inverted dimple that you can press with a ball point pen. This is a reset. It should have this button, I just can't remember the exact location if it's not right there. Hope this helps. If you have a spare cartridge try that as well, as they warp.
May 24, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Sony CDX-444RF 10-Disc CD Changer Logo
430 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
