Question about Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black
The ice maker tray is full but won't dump the ice any ideas?
  • 58 Answers
Im module bad, or sensing tray is full.
Posted on Jul 01, 2009
I have a ge tfx20jr side by side the ice maker is not dumping the water fills the tray but it won't dump
That is an electronic control ice maker and possibly worked hard for the last few years. If the ice maker will not respond to the full arm or switch being on to empty the cubes about the only thing you can do is replace it=> WR30X0327 Ice Maker Assembly
I am here if you have questions, John Tripp Appliance 911
Contact me here.
Jul 30, 2014 | Refrigerators
Ice maker won t dump ice
The ice is stuck in the tray because the heater element has not slightly melted the ice so it can be pushed out of tray. Check for continuity of element and/or proper cam operation (motor that controls all of the operations).
May 21, 2014 | Kitchen Appliances - Others
Machine keeps icing up and switching off
When you say ices up do you mean the line ices up back to the compressor. is water overflowing over sump tray? or is it dumping out drain? If you are not getting water over the evaporator plate then it will frost up the evaporator plat all the way back to the compressor.if the water is dumping into the drain during freeze cycle check the dump valve this will not let sump tray stay full of water. make sure water filter is good as this will not let sump tray stay full fast enough. is water pump pumping water over the evap plate?
Jan 03, 2014 | Kitchen Appliances - Others
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
Cme256 scotsman
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
Jul 10, 2013 | Kitchen Appliances - Others
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Samsung Refrigerator makes ice, but then quits.
I have this same thing happening, also. I have not been able to find a solution to this issue, however. The ejector blades push against the ice, apparently a gear pops loose with a loud clicking sound and the heater either does not work or never turns on. I end up killing the breaker to thr refrig,`removing the icemaker, letting it wrm up dumping the ice and putting it back in.
Aug 21, 2009 | Samsung RF265AA Bottom Freezer French Door...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
I have a GE Profile Side by side that is working fine except the ice maker won't dump the frozen ice cubes in the tray. Another party in the house decided it would be a good idea to put water in the tray...
The ice maker is basically frozen. There are two fixes for this condition. If you can transfer all of the food out to another appliance you can unplug and open the doors and let it completely defrost on its own.
the other method is to use a blow dryer. When you have completely defrosted the ice maker and thoroughly dryed it spray the ice cube tray with pam cooking spray which will act as a lubricant. When you are ready to make ice again expect the ice maker to take about 24 hours before the first batch of ice cubes are ejected.
Jun 16, 2009 | GE Profile PSS26NGS Side by Side...
Samsung 18.8 Cu. Ft. Bottom-Mount Refrigerator - Black Logo
246 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
