Question about Friedrich WallMaster WS12A10D Air Conditioner
My unit freezes up after being on for few hours. please advise. thanx
  • 3 Answers
Make sure your air Filter is clean your Evaporator being Dirty will cause freeze ups also
after changing filter and unit is completely defrosted turn on indoor fan only and check airflow coming out of register if you do not feel much air coming most likely your coil is very dirty if Both Air Filter and Coil are Clean could be Low on charge those are the most common causes of freeze ups
Posted on Jul 01, 2009
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Sunbeam chest freezer model # sbcf7wbx
The Instruction Manual for your Sunbeam Chest freezer may be found online in PDF at the following link:
http://mcappliance.com/document/SBCF5WBX.pdf
See Page 5 for information on the lights:
The "POWER" light (Green) indicates that the freezer is properly connected to the electrical power.
The "RUN" light (Red) will not illuminate when the unit is operating below freezing.
The "RUN" light will illuminate when the temperature inside the unit increases above freezing. Please be advised that the "RUN" light may come on for a period of time when the lid is opened, when new items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the "RUN" light has remained on for 6 hours or more. If this light stays on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a representative at 877-856-0202 or visit our website to request warranty service at www.mcappliance.com.
Trust this is helpful Thank you for using FixYa!
May 21, 2012 | Kitchen Appliances - Others
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
Apr 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Reset Norcold 'N61 Series' Fridge after lockout
Hi Lynn1965,
I'm Harvey the Master Plumber.
Yor problem is: Please help! Your brother phoned you on his cell from up north. He's supposed to go hunting tomorrow, and is having problems with his fridge. The nearest dealer is 5 hours away, and he's very upset.
The fridge went into lockout mode after accidentally resetting twice. Now, the lights flash, and fridge doesn't work.
Please advise how he can fix this problem himself. You both would greatly appreciate it!!
First, unplug the unit for 10 minutes. That should reset it. If not, ask if he can here the compressor motor. If not, then he has a compressor or electrical failure inside. If yes then look to a bad thermostat.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Thetford NorcoldĀ® Model DE0061
Freezing after few hours.
is the filter clean? If not then the fan cannot draw air thru the coils to exhaust moisture.. and will build up and freeze ..
Aug 22, 2008 | LG L1204R Air Conditioner
Troubleshooting with my c510
I had the same problem and contacted Garmin Europe who advised to plug into usb port of the pc and glad to say now working. It's worth a try !
Regards
Magaret
Dec 21, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Nothing Shows up on the Video Screen When I power up Nintendo Wii
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Oct 29, 2007 | Nintendo Wii Console
Not cooling or freezing
As you've said that started it with freezing up, either the unit has a leak then the refrigerant escapes or restricted system.
In this problem you need a qualified technician to repair the leak or reprocess the system and flush out the restricted system or repair kink pipe that cause restriction.
Oct 22, 2007 | Frigidaire GLRS264ZA Side by Side...
Friedrich WallMaster WS12A10D Air Conditioner Logo
256 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
