Question about Apex Digital HT-150 System
Won't even feed into tv anymore....
I returned the box I had for almost 1 year, worked great then the box wouldn't turn on one day just stayed red even with the remote or manually trying to turn it on.
Just got my new one today and it worked while I was scanning channels and then when I tried to turn the channel it just stopped working thru the TV but I do see the light changing from green to red when I turn it on and off.???? So I know it was hooked up correctly because it did work for about 5 minutes while scanning and the channel even came up. Amanda
  • 864 Answers
If you are using the RF input are you sure the channel on the TV did not change? Make sure the TV is set on Channel 3 (or 4) or use the component (red-white-yellow) outputs if your TV has component inputs available.
Posted on Jul 01, 2009
Had a great working fan for years. A week ago the remote wouldn't tutrn the fan so I installed new batteries. Still no luck. Manually, it worked. Then I used the remote to change speeds while it was...
If the manually switch works it seams there is nothing wrong with the ac unit itself ...and it may be a poor contact on the remote (for the button that starts the fan ) ..If you think you can manage open the remote ..and clean with alcohol the contacts..both sides..on the main board..and the inside the rubber button contact ..and put it back ..and see if the function is working ...If it is not ..you will need a replacement in order to work ...My advice ..just to see if it is a remote issue ...try to find a somilar one ...(or a universal ) and see if it works before going and buy one ...cause even if it seam to work manually ..this is not excludes a strange malfunction in the infrared board of the ac .
Jul 24, 2011 | Heating & Cooling
Sharper Image jumbo remote will not accept codes
Your best bet is to use the auto-search function of the remote to run through all the choices in the SAT category for the Direct TV box. I know it is more of a cable box, than a satellite box, but there are many code choices for direct TV under the satellite code listings. I think you will be out of luck for the Bose Cinewave. I am surprised that the Panasonic TV codes didn't work for you using the auto-search.
Here are the codes I have handy for Direct TV set-top boxes (SAT button) : 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216 & 217.
And for Panasonic TV's: 003, 054, 055, 062, 070, 148, 170 & 171.
And for Sony DVD's: 009 & 174.
To program your remote to the TV by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
As I mentioned, try substituting SAT for the Direct TV box, and of course DVD for the Sony player.
I hope that helps.
Dec 31, 2009 | Innovage Jumbo Remote Control
Need code-Innovage Jumbo remote for Motorola cable box & GE tv
The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Jul 18, 2009 | Innovage Jumbo Remote Control
Akai Model LCT3701AD: bought two years ago from Sam's Club at discounted price with no remote control and no service manual. I tried to find a universal remote but couldn't find one that will work on this...
If the TV fails to power ON, in about 90% of the time is due to a defective power supply.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Jun 30, 2009 | Televison & Video
My tv is stuck on a channel
You have a problem with a internal circuit.you can try by, powering off the tv for about one day. then turn it on again
Dec 15, 2008 | Proscan PS32125 32" TV
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Panasonic model# PT-47WX547 is not working
how many times does the LED blink ? Thats a error code.
Jun 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Magnavox dtv converter
my convertor box stopped displaying the green light and i cannot get it to come back on ......i have replaced with new batteries
Jun 17, 2008 | Insignia Digital-to-Analog Converter for...
RC24912 - D
1 manually turn on the device (tv, vcr. etc) to be controlled
2.Press and hold the setup button until red indicator stays on, then release the Setup button.
3. press and quickly release the desired device button (tv vcr etc). the red indicator blinks off once
4. Enter the following codes then press the channel up button and if anything happens the light will go off.
Jenson TV codes 0004, 0009, 0133
If you can't get any of these to work then you will have to do the exhausting manual version.
CODE SEARCH FOR THE RM24912
4. press the channel-up button repeatedly (up to 300 times) until the device to be controlled changes. The red indicator blinks off with each button press.
5. press and release the mute button to install the code. Then the light will go off.
Jan 19, 2008 | GE RM24912 Universal Remote Control
Apex Digital HT-150 System Logo
435 people viewed this question
Top Apex Digital Audio Players & Recorders Experts
Marvin
Marvin
Robert Rankin
Steve
Are you an Apex Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
