Question about Electrolux Refrigerators
The temperature in electrolux icon refrigerator is going up?
The freezer is now 11 and the refrigerator is 42, both farenheit, it is also flashing 'power failure', and 'high temperature' .
It beeps every couple of minutes.
I dont know if this might help find out what caused the problem, but the door has been open for a minute or two a couple times a day.
  • EZpie Jul 01, 2009
    Also the kids like to hang on the fridge doors...
SOURCE: Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Posted on Sep 01, 2008
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
tborn6
  • 700 Answers
SOURCE: SENSOR PROBLEM ON SAMASUNG SRS580DW (side by side fridge)
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
Posted on Jan 01, 2009
SOURCE: 3 beeps
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
Posted on Feb 05, 2009
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fteezer not freezing not at temperature to keep
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerator temperature showing lower than it is.
SOME OF THESE CONTROLS SWITCH TO CELCIUS. SOME DO IT ON ACCIDENT AND CANNOT BE SWITCHED BACK. LOOK AT YOUR BOOK. IF YOU HAVE NO BOOK GET IT FROM THE MANUFATURES WEBSITE. OR REPLACE CONTROL.
Mar 29, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The electrolux refrigerator icon counter depth.
According to Electrolux customer service center, the E..... F error message refers to the evaporative fan that has malfunctioned.
When ours went out the fan made a loud buzzing sound like the fan bearing went bad
Jun 28, 2009 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Refrigerators Logo
408 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
