Question about EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Algerian-47 I'm from Algeria & I've the same problem My motherboard Gigabyte (GA-P31-DS3L) = No signal, just cpu fan turned i tried every solution but nothing new the same problem with motherboard of my friend he has ecs P4M800pro-M2 no signal,no beeps,just cpu fan turning but sometimes i can start it normally, but if i shut it down don't start again
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 26 Answers
You could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Posted on Oct 21, 2009
  • 39 Answers
Hi, Your friend's motherboard ECS P4M800pro-M2) has a processor problem which is common with all 775 processors. Remove heat sink and fan. Remove processor and put it back carefully making sure it rests nicely on all the pins. Press it down with your finger and lock the bracket back. Put back the heat sink and fan. It should start, just like my motherboard with same problem.
Posted on Jan 30, 2010
  • 64 Answers
Both boards you are describing are fried, sorry
Posted on Jul 11, 2009
Ga-p31-es3g for win 98
These chipsets do not have drivers for Win98
  1. North Bridge: Intel® P31/G31 Express
  2. South Bridge: Intel® ICH7
May 18, 2014 | Gigabyte GA-P31-ES3G - Motherboard - ATX -...
Will not boot
Normally is an incompatibility with CPU. You would need to change the CPU to and older one (compatible) and update the BIOS to last version. That should fix it.
Jan 17, 2012 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Dear Sirs! I have got Gigabyte GA-EP31-DS3L rev. 2.1 motherboard, with Intel Dual Core E2220 1M_800MHz CPU at 2.4 GHz; 2 pcs of 1 GB GEIL PC6400 800 MHz DDR2 RAM in VALUE KIT2 CL5; Samsung 500 GB 7200 RPM...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 06, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
No power to GA-EP43-DS3L motherboard
When connecting your psu and its atx connector to the mainboard, have you connected the +4 connector ? If your psu does not have this extra +4 connector, you may need to buy one.
Also check you have connected the cpu power (12v 4 pin plug)
Nov 12, 2009 | Gigabyte GA-EP43-DS3LR Motherboard
I have a GA-EP35-DS3L/S3L Motherboard and i want to update the BIOS driver.
Hi go here and insert the motherboard you have, there is a slight difference between the GA-EP35_DS3L and the S3L. Download your link and follow the instructions that come with it.
Click Here
Hope this helps
Sep 25, 2009 | Intel D850MV Motherboard
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
Gigabyte m/b p3i-ds3l i have no drivers
I believe that is supposed to be P31-DS3L.
Here is the main support site:
P31-DS3L Support
Select your operating system from the drop-down menu. When you do a list of available downloads will appear.
I would Save them to your computer and after you install them from there, put them on a CD or flash-drive for future use if needed.
Thanks for using Fixya.
Jul 01, 2009 | Intel Motherboard
8GB G.Skill F2-8500CL5D-4GBPK in Gigabyte GA-P35-DS3L rev. 2.0
If they are not a matched pair it will not work. If you have two sets of matched pairs. Each pair will have to go into the right pairing slot. Example one set you go in slots 0 and 2 and the other in slots 1 and 3. If you have stickers on the memory sticks look for a group of numbers and letters one group will match it's mate.
Apr 03, 2008 | Computers & Internet
EliteGroup P4M800PRO-M2 (V2.0) Motherboard Logo
163 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
