Question about Canon PIXMA MP830 All-In-One InkJet Printer
My printer won't scan. Neither the ADF nor platen work. I put the paper in, and hit the black and white button to sart it and it just beeps.
    President:
  • 2,306 Answers
There must be an error code on the display, unless the main pcb is bad, it tells you what it needs. You need to go to the copy mode in the main display before you can copy also.
Posted on Jul 01, 2009
How do you scan?
Hi kebranch,
To scan the documents, pictures etc., This are the step just follow,
1. Scanning using the Operation Panel
2. Load the document on the platen glass or in the ADF.
3. Press the [Scan] button on the machine.
4. Then the machine switches to Scan Mode
6. Press the [Color Start] or [Black Start] button on the machine
7. MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass or in the ADF using MP Navigator.
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Canon Pixma MP450 All-In-One InkJet...
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
How do use the scan.
The machine switches to Scan Mode
Nov 23, 2010 | Canon Pixma MP450 All-In-One InkJet...
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
I have lines in printed material
If a print result of faxing, copying or scanning has uneven print density, or when copies and scans you make have vertical black lines, cleaning the platen glass may solve the problem.
  1. Turn off the power and disconnect the power cord.
  2. Prepare two clean, soft, and lint-free cloths.
    Note:
    Do not use tissue paper or paper towels as they may damage the machine.
  3. Open the document cover.
  4. Wipe the platen glass (D), the inner side of the document cover (white area) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) with a clean, soft, lint-free cloth moistened with water
    (A) ADF Glass
    (B) ADF White Reference Area
    (C) Document Cover White Reference Area
    (D) Platen Glass
    Note: If you have trouble wiping dirt, use diluted mild detergent (for dish washing).
    Caution:
    * Never use volatile liquids such as thinners, benzene, or alcohol; these can damage the machine.
    * The d
    ocument cover white reference is easily damaged, so wipe it gently.
  5. Carefully wipe away moisture from each part with another soft, dry lint-free cloth. Do not leave any residue, especially on the platen glass.
  6. Close the document cover.
  7. Reconnect the power cord and power the machine back on.
Oct 26, 2010 | Canon MP830 All-In-One Printer
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
My ADF Scan does not detect a sheet of paper in feed tray. When I push scan I get a nothing in the ADF. Is there a reset or diagnostic to work with? Scan from platen works fine. Gary
There is a small black lever toward the rear where you place the documents to scan. if it is broken or missing it can't see when you place a paper there to scan. If you can see a rectangular hole in that area with nothing in it, you will have to take apart to find and replace the sensor lever.
Jun 30, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Canon MultiPASS F50 won't copy but will scan
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
132 people viewed this question
old marine
old marine
