Home | HP | Photosmart 3210 Printer | It says the cyan car...
HP Photosmart 3210 Printer
Problem for HP Photosmart 3210 Printer
It says the cyan cartridge is missing even though
By ebrit24 on Jul 01, 2009
It says the cyan cartridge is missing even though it isn't. A new cartridge is securely in place.
Solution #1
posted on Jul 01, 2009
Somewhat Helpful)
videoman7
Rank: Guru
Rating: 89%, 34 votes
ebrit24 - Remove the cyan supply and see if there is a small metal piece on it. This piece contains a microchip that the printer communicates with. If the printer can't read the chip, it won't recognize the supply. If the piece is missing, or it doesn't work when you reinstall it, return it to the store where you bought it for a replacement. If they won't, contact HP Total Care: http://h71036.www7.hp.com/hho/cache/309717-0-0-225-121.html?jumpid=ex_R602_UAG_home/ownerservices At that point there would be a longer list of things to try to isolate the cause of your issue, and HP Total Care is the best option. Offhand, I can think of 5 different reasons for the behavior you are seeing, but I'm betting the supply's chip is not programmed correctly. Trying another supply should fix it.
Michael
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart 3210 Printer
Questions and Unsolved Problems for HP Photosmart 3210 Printer
Do you recommend HP Photosmart 3210 Printer?
Answer
Answer
Error: Oxc18a0501 It will not print Says Ink system has failed
Answer
I cant scan anything when I press the scan button on the front it tells me to refer to device... (More)
Answer
I have a Hp photosmart 3210 that give me a error on my ink cartrage, even though I placed new ones... (More)
Answer
Won't copy, message: paper size detected not supported. Copying standard 8.5X11
Answer
Print size not recommended PCS 2210 I am trying to print a photo on PCS 2210. I am using HP... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Photosmart 3210 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
