Question about Sharp EL-1197P Calculator
Printer malfunction The printer function is not working properly. When switched to print mode, it prints a series of alternating P+ and P- until it is shut off. Have had this problem with several calculators. Is this something I can fix?
  • jmintheam Apr 04, 2009
    when I am in the P P position, it prints rows of red dots with alternating -P and +P. IF I hold the switch, it will print my numbers in black, but as soon as I take my finger off the switch, it reverts back to the red dot and -P and +P problem. I can't print my work.
    Thank you.. Jack M.
  • Anonymous Apr 30, 2009
    I too am having that problem. I have called the company and they could not help. Of course, it needs to be sent for repair. By the time that is done, it is probably cheaper to buy a new one. Just not a sharp this time.
I"m having the same problem. Just started this morning when I turned my calculator on. Any suggestions?
Posted on Apr 25, 2008
My c3135 series Hp all in one printer went offline, how do i get it to print again?
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Jul 29, 2011 | HP Office Equipment & Supplies
Ok so my printer keeps reading EO3 i have tried just about everything to get it to work what can i do
Perform am EEPROM reset:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
Jun 28, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I get drag lines when printing, can you suggest a solution?
Make sure the ink levels are still good. Try to do the Clean Cartridge function on the printer. On the printer operator panel, press Copy mode > press ? or ? repeatedly until Maintenance is highlighted > press check > press ? or ? repeatedly until Clean Cartridges is highlighted > press check. Your printer will then print and begin the cartridge cleaning. Once done, try to print again and check if it is properly printing now.
Jun 21, 2011 | Lexmark X8350 All-In-One InkJet Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
You have not specified which printer you are using.
1. In a serial printer having a displaceable printing head and being selectively operative in a setting mode for setting a variable character pitch and in a normal mode for effecting a printing operation according to the set character pitch: a plurality of manually operable switches each having assigned thereto a normal function which is performed when the switch is operated when the printer is in the normal mode and having assigned thereto a setting function which is performed when the switch is operated when the printer is in the setting mode, at least one of the switches having a setting function which effects selective displacement of the printing head to one of a plurality of predetermined positions each corresponding to a different character pitch; means for producing character pitch data effective to specify a desired character pitch according to the selected position to which the printing head is selectively displaced; and storage means operative when the printer is in the setting mode for setting therein the desired character pitch data for use during a printing operation of the printer in the normal mode.
2. A serial printer according to claim 1; including controlling means for controlling the serial printer to effect changeover between the normal mode and setting mode.
3. A serial printer according to claim 2; wherein one of the switches has a setting function which enables the controlling means to set the setting mode.
4. A serial printer according to claim 3; wherein two of the switches have setting functions which effect selective displacement of the printing head in opposite directions.
5. A serial printer according to claim 3; wherein one of the switches has a setting function which enables the storage means to set therein the desired character pitch data.
Jan 28, 2010 | Electronics - Others
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
Ink not dry and significant smudging
there r various modes in the printer in which u have to print .and that u have to you said it is printing properly on ordinary paper.the printer is perfect.the photo paper have less soaking power that ordinary the photo paper can consume ink but not so quickly as ordinary paper.
u just change that printmode and then check out how it prints.
for example the modes r ----------best mode printing.
better mode printing.
fine mode printing
normal mode printing.
draft mode printing
economy mode printing.
now i f u print in best mode it will consume lots of ink but will take lots of time to print.
if u select normal mode it will consume less ink and print quickly.
u can change the settings in printer properties.
Nov 14, 2008 | Canon MP610 Photo All-In-One Printer
My iP8500
Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights
in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
4) When The LED lights in green, press the Resume/Cancel button the specified number of time(s) according To the function listed in the table below. (Each time
the Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation
completes, the printer returns To the menu selection mode automatically.)
<Destination settings procedures>
in the destination settings mode, press the Resume/Cancel button the specified number of time(s) according to the destination listed in the table below, and press
the Power button.
Note: After setting the destination, confirm the model name in service test print or EEPROM information print.
[See 3.4. Verification Items, (1) Service test print, or (2) EEPROM information print.]
To the top
0 times
Power off
When the print head is not installed, the carriage returns and
locks in the home position.
1 time
Service test print
See 3-4. Verification Items, (1) Service test print.
2 times
See 3-4. Verification Items, (2) EEPROM information print.
3 times
4 times
Waste ink counter resetting
5 times
Proceed To the step 5), and follow the destination settings
1 time
Japan: iP8600
2 times
Other than Japan, non-support of CD-R printing (A4): iP8500
3 times
Mar 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Sharp EL-1197P Calculator Logo
359 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
