Question about Canon Office Equipment & Supplies
My copy is coming out wrinkled and threw the top slot by the rollers.where the normal copy would come out. Nothing is ****,paper is full,ink level reads green?? I just made a copy yesterday and it was fine.I took out the cartridge to see--nothing?? help canon pc table top copier
    Scholar:
  • 175 Answers
There are about 4 possibilites. The paper in the drawer could have bent up corners, not laying in there good and flat, Fuser rollers bad or uneven spring pressure, something could be wrapped around registration roller or something in the paper path is catching the paper as it goes through the copier. Please rate this. Thanks
Posted on Jul 01, 2009
Why is my paper coming out wrinkle Dell B1160W
Could be a number of factors.. first humidity affects paper, if there is moisture in your paper...caused by air conditioners constantly running .
check the paper by placing the back of your hand to the paper that is in the paper tray and or the package for a very cool feeling, this will definitely cause the paper to wrinkle when coming out of the fuser unit.
Also it could be charging of the paper during the transfer stage..which can be checked by starting a copy and trying to catch it before the paper enters the fuser rollers ..too late if it comes into contact with the upper and lower pressure rollers of the fuser unit.
Also the fuser unit definitely needs to be checked as a major source of wrinkling of copies..sometime the fuser roller will start loosing some of it's coating which you can easily check by viewing the condition of the upper roller.
Anyway it's either moisture in the paper, charging of the paper, or the fuser unit is the probable suspect.. check them all.
Jul 09, 2014 | HP LaserJet 2840 Printer
When we print something,the paper comes out and is wrinkled and has some ink on it in places where there is no print. The fuser checks out fine.
Description sounds like the fuser rollers are bad.
To check it out run a 1/2 test.
Put paper in the manual feed tray. Print something. As the paper gets 1/2 way into the printer, open the top cover,(you might have to print a few sheets to catch it just right) take out the toner and look down at the paper. If it is wrinkled, you could have a bad toner cartridge. If it looks good...get the fuser replaced.
Jun 15, 2011 | HP LaserJet P3005n Printer
My canon Pixma. When it prints, the sheets come out crinkled!
This usually happens when the rollers that feed the paper through the printer are dirty. Because your printer is still rather new, I'd imagine that it is a dust problem rather that ink overflow. what you should do is get a cotton swab and some 99.9% alcohol and clean the rollers. The rollers will look like black cylinders and will be in locations that the paper goes. there are usually 2 just inside of where the paper is, and you find some under the cover where your ink is. Once you have cleaned the rollers, try to print again ans see if it still comes out wrinkled.
Mar 05, 2011 | Canon Pixma MG5220 InkJet Printer
Copy machine keeps wrinkling paper. No more jams says ready to copy and then when the paper comes out it is all wrinkled up. I have taken it apart and took air can and find a tiny piece of paper, took that...
The problem seem to be the fuser roller unit. If you know how to disassemble it ( it may be hot - take care), examine the pressure roller to see if it has the balance required of it and the 2 bearings holding the top teflon roller in place.Lubricate the 2 bearings and the collar or bushing holding the rollers in place.
Also check the tension springs on each end for even balance.
Feb 22, 2011 | Sharp Office Equipment & Supplies
Problem with paper feed - all sheets come out wrinkled with smeared ink print
Sounds like your fuser is bad, ink is not adhering to the paper and building up on a roller that is causing the paper to wrinkle.
Oct 21, 2010 | HP LaserJet P3005n Printer
My paper is coming out wrinkled when I print?
Please check the following steps:
1.Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Turn off the printer. Remove any paper trays. Look for wrinkled or damaged paper.
3. If necessary, remove the toner or ink cartridge.
4. If you find a piece of jammed paper, remove it.
5. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
6. Replace the toner or ink cartridge and paper trays.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | HP LaserJet 3030 All-In-One Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Wrinkled paper
Many possibilities can cause this....
The Pick Up Rollers could be worn out and not picking the paper up correctly.
Something blocking, or catching in the paper path
The Fuser unit rollers could be sticking, going bad..
The Exit Delivery could be warped, cracked.
After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Feb 06, 2009 | Sharp AR-207 Copier
EP4000 Back to back copying paper jams
THE INK MAY NOT BE TOTAL DRY WHEN MAKING BACK TO BACK COPIES, SOMETIME YOU NEED TO LET THE PAPER TONER DRY, LET THE PAPER COOL OFF BEFORE PUTING IT THREW THE MACHINE AGAIN, AND I KNOW ITS A PAIN IN THE BACK SIDE.
TRY IT
CANDYMANGANDY
Jan 28, 2009 | Minolta EP4000/5000 CS/PRO Copier
Paper feed problem Canon PC25 copier
check where exactly it wrinkle .it is most likely to be from the fuser unite.i.e where the paper comes out .if the fuser rollers is having mark or the paper sepration finger ontop of the roller is bend or loses its springing ability
Oct 07, 2008 | Office Equipment & Supplies
69 people viewed this question
old marine
old marine
