Question about Jensen VM9510 Car DVD Player
How to install jensen flip down
How do i hook one up in a chevey equinox
How to put pin back in shifter and put knob on a 2007. Chevey equinox
Sorry no idea as never seen this model ,if i was local i would soon sort it for you so i can only suggest you ask a local mechanic to do it for you .
Nov 10, 2016 | Cars & Trucks
Can someone help me on my chevey equinox 2005 with
Hello there.
Sounds like 'knock sensor' problem
Go here for explanation.
http://engine-codes.com/p0332_chevrolet.html
Sep 19, 2014 | Cars & Trucks
Where is the thermostat located on the chevey eqinox?
follow the the top radiator hose to engine thermostat located at the other end of the hose on engine
Aug 16, 2014 | 2005 Chevrolet Equinox
Best spakplugs for a 2010 chevey equinox 2.4 engine to use
What the manufacturer suggest. Change to other bands can also change the heat range of the plug. Which can lead to other problems knocking for pre-igntion, Hard starting in cold weather and flow plugs form low of heat range
May 25, 2012 | 2005 Chevrolet Equinox
Jensen uv10 amp hook up
how to power on the amp on my flip out headunit
Feb 07, 2010 | Jensen Car Audio & Video
How to disable the parking brake sensor on lx470
simply hook it to a togle switch. Hook one end of the switch to ground, hook the other end to the jensen, then you can flip the switch off and on to make the jesen think you are using the parking brake
Aug 16, 2009 | Jensen VM9510 Car DVD Player
Hooking up the parking brake sequence
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 11, 2008 | Jensen VM9510 Car DVD Player
Equinox dvd
i need de code number for jensen remote control to sharp tv
Aug 07, 2008 | Jensen 143307 Remote Control
Jensen VM9510 Car DVD Player Logo
59 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
