Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp light flashing, won't stay on.
I have a mitsubishi 52" tv, and the lamp light keeps flashing. It will work for a few minutes then it will shut off and the light starts flashing.
  • 64 Answers
You need to count the flashes (if it is just not constant) as that is an error code to service personnel. It could be anything from a lamp ready to burn out or thermal overload, or something else. The flashing code is important for service. Docs are available on the internet for this service data.
Posted on Aug 01, 2009
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
I turn the TV on and it stays on for a few minutes and then goes off and the red light stays on. In that few minutes there is an image.
I have had the lamp cause that problem-you should be able to buy the bare lamp-google your model number with lamp to find it
Sep 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
