A
Anonymous Posted on Aug 13, 2014
Is generic RAM suitable for Bizhub?
Bizhub C203, C253,
Konica Minolta Error Codes and Solutions
Level 2:
  • Expert 210 Answers
  • Posted on Aug 21, 2014
Expert
Level 2:
Answers
210
Questions
0
Helped
153691
Points
393
Yes, the RAM modules are in fact laptop modules. It will work from one type of machine to another, as long as you are using the same specs (as frequency, etc).
If you need anything else, just drop us an email at [email protected]
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on Oct 09, 2009
SOURCE: Bizhub C253: Error Code C-4551 will not clear.
open front door and switch-off machine
press utility buton hold press-on then swietch-on machine, on the screen right top corner u see dot (remove finger from utility buton)
after fue second u will see trouble reset touch under u will see ok switch-off machine wait 10 sec and switch on
If the error code still is on the machine u have to change cyan laser
nchalabe
Nolasco Chalabe
  • 4 Answers
  • Posted on Jul 09, 2009
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
chip_reset
  • 210 Answers
  • Posted on Aug 23, 2009
SOURCE: howto fix internal error c - 1183 on bizhub c253
C-1183 - Finishing option elevator drive malfunction
Anonymous
  • 158 Answers
  • Posted on Nov 16, 2009
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Bizhubman
Ben
  • 108 Answers
  • Posted on May 19, 2010
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
How to repair c203 bizhub error code 5370
Cooling Fan FM-6 for the MFP board, rear of machine a small fan between to large fans.
filter clean?
DUST?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
2answers
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
When trying to scan to email from Konica Minolta C203 we get an error message "From Address not set, unable to Transmit, please specify From Address" any ideas.
need to create a from address in the copier either bye at the op panel or thur pagescope look up a you tube video how to set up to scan to email with a bizhub c203 or any bizhub 3 series
Printing on A7 envelopes using Bizhub C253
does A7 show up on the as a option on the manual bypass does it show up in your printer properties??? if not measure the envelope and tell the copier with and length try that option
BIZHUB C203 FUSER
What about the fuser on a C203?
How do i disable TX Report sent to email on a Konica Bizhub c362
please give correct info... there is no bizhub c362 there is a c352 but your post is in the c203.... if its a c203 then the tx reports are in the utility/counter then common settings. i can help you more if needed
1helpful
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
