Question about Galaxy External Enclosure - Metal Gear Box II - 3.5in USB 2.0 + 1394 Hard Drive (3506UEP) Drive Case
Need user name and PW for web interface
I have a Metal Gear enclosure with ethernet connectivety. I checked my router for its IP address. When I point my browser to the IP, O get a log on screen. Do you know what they use for the generic, out-of-the-box user name and password is?
  • 36 Answers
Re: Need user name and PW for web interface
Go here for the manufacturer product page, and a link to the pdf manual for it. The starting User Name and Password are on the first page of that manual.
Posted on Dec 05, 2007
0 characters
3 Points
My computer wont show my hard drive when its plugged in
have you tried connecting the hardrive to some other computer. Is it getting detected on it?
May 30, 2011 | Galaxy Microsystems Galaxy METAL GEAR...
I have a Galaxy Metal Gear Box. It will house two hard drives. It refuses to post the second drive. I just put a brand new one in it. Same result. Rocky
If both drives are SATA (not "parallel-ATA") drives, then "swap" the physical location of the two drives, to see if only the "top" (or the "bottom") drive is NEVER detected. Or, if the "detected" drive moves after the drives are swapped, then the non-detected drive has a problem. In that case, remove the "good" drive, to see if the "bad" drive can be detected when it is the only active drive.
Jan 11, 2011 | Galaxy Metal Gear GMG 3538UCBLK 35 Dual...
I have a Mad Dog Mulltimedia external usb floppy dsrive. It does not work on my windows 7 computer. Can you help me find a driver or whatever I need? Virginia Wilbur
Mad Dog is, unfortunately, out of business by all indications and there is no support available from them. I suspect that Windows 7 will not have a driver that is compatible with the enclosure's interface. Depending upon what brand/model of actual hard drive is inside the enclosure (Western Digital, Seagate, whatever) you may be able to dismantle the enclosure, remove the actual disk drive, and use it in another enclosure with an up-to-date interface. That is only a would require a certain amount of mechanical expertise and a good phillips screwdriver ;-)
Dec 29, 2010 | Mad Dog Multimedia USB 2.0 External Drive...
My Metal Gear Box external hard drive has a flashing blue light, and my computer does not detect the external hard drive, what is the problem?
the weird cheap power supply they used has failed. I will never buy another galaxy product. This whole time I thought the hard drive crashed, but it was the enclosure all along that died at about a year.
Nov 14, 2010 | Galaxy External Enclosure - Metal Gear Box...
My external hard drive is not being recognized by my computer.
Try using another USB cable or different port on your PC. It also may be that it needs external power, Check to see if its plugged in to the wall, if it is, it may be that you need a new power supply.
Jun 03, 2010 | Galaxy Metal Gear GMG 2518UAS External...
Gear's wont change into 3rd 4th gear and has high revs
Take your external to your local car dealer and have them reformat the gearbox lmao!
Dec 17, 2009 | Galaxy External Enclosure - Metal Gear Box...
I-rocks ir-9200
when u want to use them them in an encrosure u first have 2 remove the metal bars that attach the hard drive to the laptop once the bars r removed it iz ready to fit in the encrosure
Apr 22, 2008 | i-rocks External Hard Drive Enclosure -...
Metal gear enclosure 3.5 box 2
Sounds like you haven't formatted the external Hard-Drive.
You need to allocate a file-system to the free space on your hard drive. You can do that in Disk Management and use the format option. You can select from two file system formats: FAT32 and NTFS. I would recommend NTFS because it is a journalling file system (recovers quickly in case of a crash).
Oct 20, 2007 | Galaxy External Enclosure - Metal Gear Box...
Galaxy External Enclosure - Metal Gear Box II - 3.5in USB 2.0 + 1394 Hard Drive (3506UEP) Drive Case Logo
223 people viewed this question
Top Galaxy Hard Drive Accessories Experts
Are you a Galaxy Hard Drive Accessory Expert? Answer questions, earn points and help others
