Question about Sony RDR-VX500 DVD Recorder/VCR
I am not able to format a blank DVD prior to dubbing from video(both +R and -R). Am I to assume if the "format disk" option in the menu is grayed out that the machine is telling me the disk does not need to be formatted? I have not been able to play back my recordings on any other DVD player or my PC. I'm guessing it is a formatting or finalizing problem. But those options are not available to me.
  • vfazzi Jul 03, 2009
    So, When I put in a blank +RW it says on the TV screen "unformatted disc please wait" BUT on the DVD player it only says "loading" for quite a long time. I found that I needed to format the disk manually using the system menu/disk settings after it finished "loading".
    I also found what I heard here to be true. This machine does not like -R or -RW use only + disks.
    Finally, make sure you switch back and forth between the DVD and Video functions in order to carry out the various formatting and finalizing tasks. For Example,the machine will have to be in the Video mode to dub a tape to DVD, but then you must put it back in DVD made to finalize. This seems obvious now, but it is not spelled out in the instructions and I became frustrated when I thought that the disk would not finalize. Of course not. I was still in video mode.
    Scholar:
  • 57 Answers
Vfazzi - You shouldn't have to format a DVD - it should do that automatically when you put a blank one in, or when you start the recording by pressing REC. After the recording is done, you will need to finalize to play it in another player, and the option should then be available (It would "know" not to let you finalize a blank disc).
Michael
Posted on Jul 01, 2009
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have a Toshiba DVR620ku DVD/VCR combo. I have the Format Mode properly set to "Video mode." I put in a new, unformatted DVD-R, and the player should format the DVD, but it doesn't. I click...
My brother had the same problem. Toshiba tech support said the disc was already formatted, so the DVD MENU option would not be available. He went straight to dubbing and recorded to the disc. After recording, the DVD MENU option was then available. He thought the disc was not formatted since it was straight out of the package and he always had to format other new discs. Perhaps your disc was actually already formatted?
Oct 27, 2010 | Toshiba DVR620 DVD Recorder/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Can not get dubbing to work
Samsung's solution to many problems seem to be the type of dvd. Try using a dvd-r. I am able to select dubbing with a dvd+r, but the +r discs won't play in other dvd players. Apparently, -r is the only disc to use with this box to avoid issues. The +r records the soundtrack a few seconds off of the video track.
Dec 14, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
DVD Menu selection not available from Setup Menu
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Dec 05, 2008 | Televison & Video
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LG RH265 - Problem when trying to register blank disk/dubbing
The DVD needs to initialise the disk first. Come out of the HDD dubbing menu and press DVD on the remote. The blank recordable disk should be recognised and you should see Initialise disk? on the screen. Press Start and hey presto, you can now dub from the HDD Movie dubbing menu (as per the manual instructions).
Feb 15, 2008 | LG RH177 DVD Recorder/HDD Recorder
Problems dubbing from hard drive to DVD RW disk
Switch CD R or DVD R
RW disks are not suitable for this work.
Dec 17, 2007 | Computers & Internet
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sony RDR-VX500 DVD Recorder/VCR Logo
419 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
