My top load Kenmore leaks water on the cycle when water is being pumped out of the machine.
  • hans911 Jul 01, 2009
    Yes every time the machine pumps to drain water is visible under and at front. Not all the water is on the floor just some. I assume a pump or hose leak?
  • Jim Thurston May 11, 2010
    Is the water visible under the machine in the middle at the front?
  • Washing Mach... Master
  • 8,220 Answers
The pump is really easy to replace on these. You can access it by using this GUIDE. To verify if it is indeed the pump and not a hose you can run the washer with its case remove.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 leaks in
yip no worries pump is the same as phillips/whirlpool 5min job only 2 clips
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Apr 26, 2009 | Kenmore Washing Machines
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
Kenmore elite, water leak
Check the mix valve area where the water enters the machine, during the fill.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 - water leak not from hoses - could it be the pump?
Hi Gleen you probably need to remove the rear cover to expose the in side of machine.
Note if you could post a model number I could tell you for sure what would be the best way get to the pump.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
