Question about Dualit Vario 4 Slices Toaster
The timer gets stuck and the toaster will stay on.
In order for it to turn off, you have to manually turn the dial. Wondering if it's fixable and if we can just buy a specific part for it.
    President:
  • 3,433 Answers
Open the bottom and shake out the crumbs. Kidding. Toasters are generally a disposable item. Depending on your affections for this crisping critter, you may find a part and you may not. I'm going to open a five dolar fis store for small appliances. So many are trashed because of penny parts. Let me have the make and model and Serial # and let me research this for you. Might as well open the doors here. This is a grand opening freebe.
Posted on Jul 01, 2009
The timer dial has stopped working. Is there an easy fix or does it mean a new timer from Dualit
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch since it can not be repaired
Jul 28, 2011 | Dualit 40352 4Slice Toaster
The dial on the toaster keeps getting stuck.
This one of the most frequent problem of dualit toaster. Almost all have to be replaced after 5-8 years of use.Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch.
Jul 13, 2011 | Dualit 40352 4Slice Toaster
I'm having problems with the dial you turn to turn on the toaster. It will not stay on, just turns back to off position. The toaster will work if I stand and hold the dial on the entire time...
try turning it all the way on if it's a timer switch,, then rotate back, If its just a on off switch, your going to have to replace it, unfortunatly its in the UK and thats the only place I could locate it,, but heres the link for that
http://www.dualit.com/spares/01362
Jul 12, 2011 | Dualit 20084 2Slice Toaster
Hi, The dial on our Dualit toaster gets stuck on
The timer can be rplaced by any good handyman. You can get a new one on ebay there are two types make sure you get the right one. Replace it before someone forgets to shut it off and the toaster smokes up the kitchen. Its a common problem with the dualits but the switch is not cheap and you can only get it from England. The good news is the replacement seems to be better made than the original
Jan 09, 2011 | Dualit 20084 2Slice Toaster
The timer gets stuck and does'nt move anymore after for example 2 minutes. If I move the timer manually a bit further it will get stuck again after a short time. I hav tried to put some Silicone Spray HR...
Timer dials are easy to replace if you can find the part. Start with the manufacturer, but if that doesn't work trying Googling it. Any timer switch that will fit will work. It's just a simple switch.
One nut to hold it to the casing and two wires to connect it. It usually doesn't matter which wire goes where, but note their order when you take out the old one (take a cell phone photo) just to be sure.
Oct 15, 2017 | Dualit 30081 3Slice Toaster
The timer dial gets stuck repeatedly, resulting in very burnt toast that I have to rescue before a fire happens. I have not tried to fix it. This problem occurs now every time I use the toaster.
> occurs ... every time ...
How much would it cost to rebuild your home after a fire?
How many months would it take to rebuild?
How much would it cost to replace your toaster?
How many minutes would it take to purchase one?
Buy a new toaster, upgrading to 4-slices. :-)
Oct 05, 2010 | Dualit 20247 2-Slice Toaster
The dial gets stuck and the toaster does not shut off. How can I repair this?
You need a new timer they are available on ebay but they are pricey
Sep 27, 2010 | Dualit Vario 3 Slices Toaster
Intrametric T-101R timer used to turn a swimming pool pump on and off. The dial not longer turns so I need to manually turn the timer on and off. Manually it works fine, but the timer feature doesn't...
Check wires from timer motor to terminals. If you buy the same brand of timer, you can "pop" timer mechanism out and replace it with the new one you take out if it's enclosure. Be sure the tripper hands are on the dial.
Jun 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Broken timer
The timer is also an electrical power switch and it can not be fixed. In any case and for safety reasons also you need to replace it.
It can be easily removed by removing the bottom panel and remember to make some notes on where each wire is connected so you will put them back in the same order with the new timer switch.
Good Luck
Nov 24, 2009 | Dualit Kitchen Appliances - Others
Delonghi toaster oven wont turn off
have you cleaned the inside of the oven lately?  With the unit unplugged!
Mar 26, 2009 | DeLonghi DTT900 2-Slice Toaster
Dualit Vario 4 Slices Toaster Logo
155 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
