Question about Mitsubishi WD-60735 Projection Television
No pic with sound and turn off by itself with a
No pic with sound and turn off by itself with a red status light
  • 34 Answers
The red light is a status indicator that means your tv needs to be serviced. Most likely your bulb burned out or failed. You can purchase a replacement bulb online. I have solved a few questions on how to replace a bulb on this site. Check my profile for those posts if you need help with that.
Posted on Jul 26, 2009
What caused it to shut down?
Probably abrupt power supply failure
Feb 22, 2016 | LG Televison & Video
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
My 32in sdtv red power light,no pic no sound
hi there, this may seem like a sstandard problem, but differs from mfg. to mfg. in the sony tv's it is usually an open cap in the stand-by power supply, since you werent specific in your problem, there can be many solutions even for a single series or group of tv's even within the same mfg. give me specifics and i can answer more precise. hope this helps even a little.
Jun 12, 2008 | Televison & Video
No pic on 360
do a status check and it should tell u and after that wat ever seems be the problem read by selecting mor info then call 1-800-469-9269 and tell them about it and they will troulble shoot unless u have xbox live send 2 xbox/support hope i have helped u with ur problem if not then srry
May 22, 2008 | Microsoft Xbox 360 Elite Console
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Mitsubishi WD-60735 Projection Television Logo
331 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
