Question about Amana ARB2217CSL Bottom Freezer Refrigerator
Refrig is not cooling
ARB2217CSL
Compressor running (or at least something is making noise)
Freezer is cold
Air being pushed out the back vent
  • 42 Answers
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Posted on Jul 02, 2009
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
The freezer is really cold....but the fridge isn't blowing any cool air.
there is a vent control, in the Refrig area, that directs air between the refrig and the freezer. Check to make sure its not shut off that will blow all the cold air into the freezer.
Jul 26, 2009 | Refrigerators
I own a maytag rsw 2700 refrig. motors run lights
Hi jtc1280 when you say motors are running,does that mean the compressor motor or is this just the cooling fans.
I suggest you remove the cover on the rear bottom to access the compressor motor and check the compressor by putting your hand on the compressor be cautious when doing this the compressor may be hot if not working correctly un plug the compressor and plug back up with hand on compressor see if you can fill the compressor running this motor runs with very little noise. If this motor is very hot insure that the colling fans are working and also that the condensing coil is free of lint build up which can make the unit over heat if this area has a lot of lint build up unplug unit clean the bottom out with air hose and vacuum if no air is available just use a dust brush to clean good let the compressor cool for 30 or 40 minutes before plugging back in.
Jul 07, 2009 | Refrigerators
Refrig and freezer not getting cold
HI, Can you hear the compressor running? Does it click like something is trying to start but can't? It sounds like the compressor is not running. The compressor should have a 5 year warranty. They are having problems with these compressors so, you might want to call Amana and see if it is under warranty. I hope this gives you some help. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Amana ABB2227DE Bottom Freezer...
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
My 16-year old refrig makes a single knocking noise when it starts to cool. It sometimes makes that noise if it's just sitting there. Just replaced the fan assembly behind the freezer wall. It wasn't...
Just a thought..fan motors usually have some front to back play (looseness). When the fan first turns on ..it may make contact with something, however after a few blade revolutions, the air pressure will push the fan one way, and allow it to be quieter. If not the fan, the compressor will also have some starting torque possibly causing a knock.
Apr 20, 2008 | Refrigerators
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Amana ARB2217CSL Bottom Freezer Refrigerator Logo
186 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
