Question about Refrigerators
WATER LEACKING UNDERNEATH WHILE PUSHING TO GET WATER FROM THE OUTSIDE
  • 58 Answers
The water valve or water tubing is leaking. test and inspect to find leak, then replace the leaking component.
Posted on Jul 01, 2009
When my car is in idol about 5 min into water starts coming out then it makes loud sound like the water is settling i just replaced the radiator
i need more info to help but it sounds like a bad head gasket depending on where the water is coming from
Feb 09, 2014 | Dodge Neon Cars & Trucks
2005 magnum over heating and leacking water from coolant valve
replace valve fill with coolant being sure to bleed cooling system
Sep 09, 2013 | 2005 Dodge Magnum
Radiator leacking from drain with the drain **** in
If the leak is coming from the drain and it is tightly closed, the drain valve is back and should be replaced
Dec 15, 2012 | 1990 Ford Tempo
Leaking water from underneath.
Hello my name is Heath it will be my pleasure to assist you. The drain should be in the back of the unit outside . If you lean the air conditoner slightly toward the outside it should drain outside.
Jun 28, 2010 | Frigidaire FAA084P7 Thru-Wall/Window Air...
Pool of water at the bottom after is is ran
Where is the pool of water. At the bottom of the dishwasher (inside) or on the floor (outside)??
I'm assuming outside...You'll need to determine if the water is coming from the door or out from underneath the unit.
If it is coming from the door, this is usually the door gasket. Easy to replace and not too expensive!
If it is coming from underneath, then the leak is coming from a seal around where the motor shaft penetrates the interior cavity or there is a crack in the cabinet cavity itself.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Apr 27, 2009 | GALAXY Microsystems 25.4 cu. ft....
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Kenmore Gas Dryer-70 Series is condensating and doesn't heat up
reck vent starting behind dryer then to outside try drying a load with vent disconnected may get warm but will prove or disprove vent problem..water is from clothes and is recondenseing because there is no escape to outside
Jul 02, 2008 | Kenmore 63942 Dryer
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
