Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Xbox 360 picture too large
The picture is too large for the screen and is cut off at the top. I have tried all of the picture settings in the menu select and the TV's remote gets no response whatsoever.
    Problem Solver:
  • 3 Answers
Have you tried just clicking on your left or right arrow to change the screen size without using the menu button?
Posted on Jul 02, 2009
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
How do you connect xbox 360 to wi fi got the receiver but cannot pick up my modem
Make sure you have Turned on the console and navigated to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Make sure that is how it is set-up and then try to preform a connection test
Oct 14, 2009 | Microsoft Xbox 360 Console
Picture won't come up on my xbox 360.
When it is starting up push down y and pull the right trigger the console will reastart on default settings and u it will show the picture if this dosent work try when you hear the menu screen come up. It worked for me but now i have lines going acroos hopefully you wont have tht problem
Jun 29, 2009 | Microsoft Xbox 360 Console
Screen has black line down the middle.
it sounds like a setting in the progressive scan or screen ratio menu.
May 04, 2009 | Video Game Consoles & Games
You need to set the monitor up. I have a 42" LCD TV, and there is a menu where you can set the aspect ratio to 'Auto', 'Full Screen', or "4:3". I had a similar issue with my DVD player. I'm sure if you go through your monitor setup menu, you should be able to solve this problem.
Apr 17, 2009 | Video Game Consoles & Games
FLICKING
hi what you need to do is get onto the tvs menu and turn off the auto function that selects best picture like widscreen 16.9 the screen ratio if you put it on one of the other settings other than auto you wont have this problem just try each setting untill you have correct picture so as it fills the screen.
Let me know if you need further asssistance ok
Feb 29, 2008 | Toshiba 32AF62 32" TV
Cutting off the picture
please try once more in the memu on tv
Oct 14, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Xbox 360 Elite connected to Mitsubishi HDTV Model No. WD62528
Hudeez: 1. Did you check your TV Menu Settings ?? 2. Also on the XBOX 360 Menu. Go to the SYSTEM MENU (PURPLE). CONSOLE SETTINGS and select DISPLAY. Then you'll find the HDTV Settings and pick your resolution for TV Set. Done....
Jun 05, 2007 | Microsoft Xbox 360 Console
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
523 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
