Question about Microsoft Xbox 360 Console
Xbox 360 is getting one red ring on the bottem right side and error code is E 74
  • 69 Answers
Broken solder ball under G.P.U , X clamp it , but get it done right.
There is a small cluster of connections under the G.P.U. (solder balls)
that are subject to extreme heat loads so they harden /soften ,till they crack
open and wh ala 1 red or 3 red...
If you want to see for yourself goto
xboxrepair
.com/">www.all-xboxrepair.com
was that too much info?
Posted on Jul 01, 2009
  • 90 Answers
This is a AV error. I had the same problem today. it was the switch on the side of the AV cable.
  • consolemods Jul 01, 2009
    Before you go doing a X-clamp fix you should check you AV cables. try switching cables if you have a spare set. If you have tried the cables I would deffinately reccomend a X-clamp mod. I just reapaired one today and all I had to do was change the switch from HDTV to TV.
I used the scan and pressing the open disk, I got back 2211, but there is no error code of this code. Any Help?
Xbox 360: THE LITTLE ENGINE THAT COULDN'T.
Seriously, one in three dies under warranty. Call microsoft and complain, they will be good to you. They might even let you keep your old hard drive.
Nov 26, 2014 | Microsoft Xbox 360 Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
My xbox 360 has 3 red lights and is not working
Turn your Xbox off for like 3 hours..... Turn it back on, if ERROR 74 shows up then you have RROD "Red Ring Of Death".... https://myservice.xbox.com/en-us/Pages/Welcome.aspx If you haven't had it for three years yet, you can send it in to Microsoft and they will fix it free of charge... Next time, try to use the Xbox less.... The more you use it the more it is prone to overheating melting a motherboard chip thus causing error 74
Jan 08, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
When you turn on the console it has a weak hum and there is only one red ring where the 4th player green ring is supposed to be and its on a black page and it says"system error. Get help." or...
E74 is due to an inherent engineering flaw and will continue on new consoles until Microsoft institutes a revision.
Call Microsoft XBOX support and provide with them with your Xbox's serial number and the description of the error code.
u can download repair guide click here
Dec 17, 2010 | Microsoft Xbox 360 Console
Third ring turned red it shows E 74
:( Feel Sorry for you. 3/4 of RROD means a SUPERFRIED Xbox. give it to a hobo and say Merry Fakemas!
Sep 06, 2009 | Microsoft Xbox 360 Console
Code error 74
Your console has the E74 error message. Your system is dead, call Microsoft cutomer support. It is covered by the warranty so repair is free.
Jul 30, 2009 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
Jun 30, 2009 | Microsoft Xbox 360 Console
Error74
http://forums.planetxbox360.com/xbox-360-hardware-discussions/17416-1-ring-error-code-74-help.html
Scalar chip or faulty video cable
Nov 20, 2008 | Microsoft Xbox 360 Console
E 74 message
hi if your lights are blinking red its called the ring of death now if u got the xbox 360 elite it can some times fix its self but on the older xboxs you will find sometimes they can do the same but if this does not go back to how it was befor u may have to take it back to where u got it from and get them to either give you a new one or they will have to send it of to get it fixed ive had this problem with 4 elites now so i know whats goin on i have had 4 new elites in 6 weeks so i no what your going though buddy so i hope this works for you m8
Apr 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
115 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
