Question about RCA D52W19 52" Rear Projection Television
Rca 52wh74 i can plug it up and the power light will come on by itself and 5 seconds later it will cut off and it has no picture or sound,can someone help me with this? thanks
  • nappynuts200 Jul 01, 2009
    what can i do to fix this?
    is the capacitor a cp150?
  • 11,896 Answers
Very possible you have a bad capacitor in the power supply
Posted on Jul 01, 2009
It wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Jan 20, 2010 | RCA HD56W58 56" HDTV
I have a RCA L32HD32D, will be on for 1 to 5 min. later goes off
check secondary power supply. check capacitors and apply fresh solder.
Jun 01, 2009 | RCA L32HD32D 32 in. LCD HDTV
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
42' rca problems
my tv did the same thing my power supply board had went out had to replace it now I have no problem did you notice a hiss when you cut it on if so it is the same problem
Apr 07, 2008 | RCA HD52W59 HDTV Projection Television
Tv powers on and off
Sound
Sounds like your bulb is nearing the end of its life span you will be needing a new bulb soon.
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 Turns Off
Hi, Based on your post/description, my guess is a loose connection or a cold solder problem (higher probability). Not unless you want to make another "30 mile trip", you have to find a local tech who is comfortable working with live/hot sets. The usual precaution on working with live/hot units and HV applies. This involves opening the back cover, powering the unit and with a foot long + insulated rod (I use a broken fiberglass fishing rod), poke around the inside of the TV, part/move the wires about, also press on the boards slightly. The idea is locate the loose connection or the cold solder. Soon as located, poweroff and resolder. If there is a component/board failure, the unit would not have operated intermittently. There is a big chance that the loose connection or cold solder just worsened and that cause the recent "chosen not to work". Further, the power light still turns on and you have not posted any other indications such as a beeping sound or blinking leds/lights which normally indicates failure. Hope this be of assistance/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W19 52" Rear Projection Television Logo
254 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
