Question about Emerson CF945WB Chateau Royale Weathered Bronze Ceiling Fan
How do I get the switch code for an emerson ceiling fan?
I have a model CF 945 fan and a remote with switches inside.  Where do I find the switches on the fan to match with the remote?
  • 672 Answers
There are switches in the remote and in the switch housing. Check this Emerson link for specific instructions. http://dl.owneriq.net/0/00837059-3b79-4074-8261-2ed4fed64384.pdf
Posted on Jul 01, 2009
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
I have the Hampton Bay Ceiling Fan and Remote. Model UC7083T. My son was playing with the battery cover and i think he moved the switches. The problem is i don't know what their original position was....
You have to go inside the actual ceiling fan. If you look on the part right above the light, there should be 3 or 4 screws in the side, connecting the light setup to the body of the fan. Unscrew those screws and disconnect the wiring harness. Inside the now open fan wiring, you should see a little box, that is the remote receiver. Either on one of the sides of the box, or inside that box will be the code. It will look just like the code switches on the remote. Make sure they match up, clip the wiring harness for the light and the fan back together, screw those screws back in, and you should be good to go.
May 09, 2011 | Hampton Bay 24002 Ceiling Fan
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
I need a remote
You can buy a remote kit at most electric or home improvement stores. It will come with instructions and needs to have the receiver installed in the canopy of the fan itself. They usually have dimmers for the lights on them, so do not use CFL bulbs in the fixture. Lowes sells one made by Harbor Breeze for about $30-$40. Good luck.
Feb 27, 2010 | Hunter 23827 Classic Original White 42"...
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Remote midway II does not run
disassemble your fan and check the two terminals of power inside the motor maybe the wires were the problems that is why neither your fan nor ligth is on.
Mar 03, 2009 | Emerson Fans CF929BS Midway II Ceiling
I NEED CODES TO MY WIRLESS CEILING FAN REMOTE
What codes? There are 4 dip switches (see DIP switch wikipedia) inside the remote control and 4 inside the sensor that is inside the fan. They have to be in the same position. If you don't feel like messing with the one inside the fan, keep changing the ones inside the remote. U= Up, D = Down
U-U-U-U, U-U-U-D, U-U-D-U, U-D-U-U, D-U-U-U, U-U-D-D, U-D-U-D, ... D-D-D-D (*There are 16 possible arrangements*) On e of these arrangements will work (has to work) if the remote components are not damaged.
Nov 12, 2008 | Universal Remote Control Hampton Bay...
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Emerson CF945WB Chateau Royale Weathered Bronze Ceiling Fan Logo
543 people viewed this question
Top Emerson Dryers Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jim Thurston
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerson Dryer Expert? Answer questions, earn points and help others
