The engine idles normal when first started
SOURCE: Idle is very very High
Check under the hood for any small vacuum hoses that are broken or disconnected. You will find a lot of small hoses! Most high idle problems are the result of a vacuum leak. Try idling the engine and spray short bursts of WD40 in different areas under the hood. If the engine idles lower when the stuff is sprayed in an area, that is more than likely where your leak is. Don't go overboard with the WD40, just short bursts.
SOURCE: High Idle
get a code reader like the Actron CP9015 Code Scanner, for 20 dollars and follow the directions. count the flashes and post the code if you need further help
SOURCE: 1989 ford f350 460 gas
89 Has EFI not carb. I vote to give you a ZERO!! The problem is more likely the IDLE AIR CONTROL VALVE (no sh!@#) "IDLE"????
