Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
My lcd is no longer working. my question is to change the ink. well, i have 6 cartridges. how do i know what one is empty? the indicator on the lcd does not light up, so i can't tell what one is empty. is there a way i can manually look at the cartridge and know? thank you for your time...Renee
  • Epson Master
  • 511 Answers
See epson status monitor.
Posted on Jul 01, 2009
Ink light is on. which cartridge needs to be replaced
The printer's indicator lights tell you when to obtain a replacement ink cartridge by flashing when ink is low, and when to replace an empty ink cartridge by remaining on when ink is depleted. The LCD panel also displays INK LOW or INK OUT.
Even if only one ink cartridge is empty, the printer cannot continue to print.
Nov 24, 2014 | HP DeskJet 960c InkJet Printer
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
How do i change my ink cartridge on my mfc-295cn
Hello and welcome to FixYa;
  1. Open the ink cartridge cover. If one or more ink cartridges is empty (for example Black), the LCD shows "Cannot Print (Replace BK Ink)" or "B&W Print Only."
  2. Press down on the release lever to unlock it and take out the ink cartridge for the color shown on the LCD.
  3. Open the new ink cartridge bag for the color shown on the LCD, and then take out the ink cartridge.
  4. Turn the green knob on the protective yellow cap clockwise to release the vacuum seal, then remove the cap (1). You must hold the ink cartridge as indicated in the picture below.
  5. Each color has its own correct position. Insert the ink cartridge in the direction of the arrow on the label.
  6. Gently push in the ink cartridge until it clicks, and then close the ink cartridge cover.
  7. The machine will automatically reset the ink level.
I am sending you the link that shows you illustrated pictures to help you through this.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000030/faq000230_012.html?reg=us&c=us&lang=en&prod=mfc295cn_all&Cat=7
You should be good to go!
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 30, 2011 | Brother IntelliFax Fax/ Phone/ Copier
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
shown on the LCD.
c Open the new ink cartridge bag for the
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
f Lift each lock release lever and push it
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
How do you change the ink
See the following URL for diagrams: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002072/Mini3_Mfc_Base_UsaEngUsr_B.pdf
Open the ink cartridge cover, on the front right side. Pull the lock release lever down and take out the empty cartridge (it has a little ink left). Now open the bag containing the new cartridge and take out the cartridge. Take off the protective yellow cover and make sure you do not touch the area that was covered. Push the new cartridge into place; there is an arrow on the side that indicates the direction in which it goes into the printer. Lift up the lock release levers until each one clicks (as needed depending on the number you unlocked before). Close the ink cartridge cover and answer the queries about the new ink to clear the counter. The counter will be automatically reset if you wait to see Near Empty and Ink Empty on the LCD screen before you change the ink.
If the LCD screen still reads Install, check that the cartridges are fully seated in their slots.
I hope this helps.
Jan 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do i change the colour cartridge for a epson style c42+ printer - if i press the red LED button for 6 secs only the black cartridge comes into the open.! how do i get the colour cartridge into view ?
after the black cartridge moves to the ink changing position, push the 'ink' button one more time to move the carriage to the position to replace the colour cartridge. in some cases this will only work when the printer indicates that the color cartridge is empty.
Oct 12, 2009 | Epson Stylus C42+ InkJet Printer
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Re install ink
I know this is a dumb question but did you remove the tape off he bottom of the ink cartridge? Also sometimes if you are using a generic ink cartridge the machine may not recognize it. Make sure the cartridge is seated in properly and that it is in the correct location. (not color spot). Hope this helps. John
Sep 07, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
163 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
