Question about SanDisk Sansa e250 MP3 Player
Sansa e-250 does not show SD micro card
Nothing happens when I plug in the SD card. Database refresh did not pick up the songs on the card
  • par3eagle May 26, 2008
    1 gig sd card does not show up in my computer as second drive. am using vista.
  • Anonymous Mar 15, 2014
    sd card showing no result. its not working. the songs wont run.
I actually thought I had this same problem, but it ended up I had not put the card in correctly (or, for that matter, fully) and simply needed to put the card in for the songs to show. Make sure the card does not stick out more than 1 mm or so from the device, I had mine nearly a full centimeter outside the device and was for some reason convinced it was in the MP3 player correctly.
Then again, maybe I'm just silly and none of you have that as your problem :D
Posted on Jul 20, 2008
    Problem Solver:
  • 13 Answers
Hmmm.... put your sd card in.Try this go to settings and go to usb mode. Then click on one of the following msc try it. then mtp try plugging it back into your pc each time and go to my computer and see if there are 2 sansa drives.
If this did not help,
put the sd card in power on the mp3. if no songs from the sd card are there hold down the power button for 20 sec untill it restarts.
If nothing still.... download the Firm ware updates. Heres a link
Click here
Posted on Nov 11, 2007
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 Player not reading SD 1GB Card
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Hack!!! please help!
You device is too full. You need minimum 6MB for the "music database". The more music you have, the bigger the database needs to be. Try freeing up 30MB or so, that should solve it. Please add to the question, dont select NOT HELPFUL if this didnt work. Best of Luck.
Sep 26, 2007 | SanDisk Sansa e250 MP3 Player
Refreshing database - Everytime
there nothing wrong its jsut the way the mp3 player refreshes the play lists mine does it too
Feb 06, 2007 | SanDisk Sansa e260 MP3 Player
It's only reading the data on the micro sd, it just has to have that little time to do that, even if there is hardly anything on the sd, it still needs to check it out, just like it does with its own drive. Don't seat it, if you don't like it see if you can put the data onto the main drive of your sansa.
Feb 06, 2007 | SanDisk Sansa e200 MP3 Player
How do you refresh database?
This just means that the player is refreshing the songs on the list, it does not mean that you have to do anything.
Feb 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
108 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
