Question about Dryers
My dryer heats up but will not dry the clothes. I have checked the lint filter, vents, hose but everything is clear. I have noticed some condensation under the dryer after it has been on for a while. Any suggestions?
  • c-rae7 Jul 05, 2009
    How do I get to it?
  • c-rae7 Jul 06, 2009
    The opening for the tube goes to the front of the dryer, still round. Is there a space above that could be blocked and do you know how to get to it without taking the entire dryer apart? Or am I reaching and the problem is more serious?
    President:
  • 1,723 Answers
Inside the machine in the back there is a metal box that captures the air coming from the drum. This can become blocked with lint and cause your problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
  • Craig Butler
    Craig Butler Jul 06, 2009
    If you unhook the vent tube you can reach in the back and see if it's blocked, unplug the machine.
Lots of heat but don't dry
The usual reason for this is poor venting. If the dryer cannot exhaust the moisture-laden air that is created during the drying cycle, the moisture simply condenses back into the clothes. Ensure that the dryer is properly vented to the outside and that the lint filter(s) are clear of debris.
Dec 30, 2015 | Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Our LG dryer doesn't dry clothes very well. We usually have to run the dryer 2 or 3 times to dry our clothes. I've checked the lint filter, hose and vent. Everything is clear.
if you have checked vent all the way out to termination point and sure that it is clear and not obstructed with damp lint then i would say you possible have a bad thermostat on the heater... this regulates how often and how long the dryer heating element runs and stays off.it has a open temperature and a shut down temperature... i would suggest replacement of that first... it is located on the heating element of unit... it is a round disk shape like bi-metal with 2 wires attached to it...
good luck to you....
Feb 13, 2011 | Dryers
I have had this elect dryer for about 3 years. Same prob from the start.. Takes forever to dry any load of clothes.. Litterally 4 plus hours to dry 5 bath towel and 6 or 7 wash cloths.. this is...
Long drying times can commonly be the result of improper or restricted venting.
Examine your vent hose. How long is it? Too many bends?
Check to make sure your vent hose is clear and free of an restrictions.
If vented outside, is the flap opening properly and free of lint buildup and is the hose clear?
Pull your dryer away from the wall and disconnect the vent hose, use a vacuum or brush to clean out the inside of the hose, sometimes shaking the hose a bit (if possible) will free any lint buildup that your vacuum or brush may have missed.
Don't overlook cleaning out the pipe that the hose connects to on the back of the dryer.
Lastly if you have a lint filter that's on the top like mine, remove the lint filter and check for obstructions there, use a lint filter brush and clean well, this is often overlooked and a major cause of poor drying, overheating, or fire.
Feb 11, 2011 | Dryers
My dryer will not dry my clothes what should i do to fix this problem. It takes 3 cycles to dry a load completly
if its a condenser dryer make sure the condenser itself is not blocked up ( usually located at bottom of dryer, looks like a metal box). clear any lint build up and u can also flush it through with water. obviously check the filter also.
if a vented dryer make sure the vent hose not kinked or blocked, check the actual vent outside on your wall as wel. sometimes if wrong vent fitted ie one with wire mesh meant for extracter fan, can be blocked up with lint
Sep 25, 2010 | Kenmore Dryers
My dryer is saying to check filter but the fileter is clean, the vent hose in the back is clear and it is still not drying the clothes. The dryer is putting out heat, but the clothes are still wet after a...
There is a restriction in the dryer venting system. If the moisture is not removed from the dryer thru the moisture vent then the clothes will get hot but not dry. You will need to remove the vent hose at the back of the dryer and look inside the vent pipe and see if it is restricted with lint. You might need to reach up inside the vent with your hand and pull out the lint. Also some of the newer dryers have a fan assisted venting system and if the fan stops working that can cause this issue.
Dec 07, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My ge dryer takes 5hrs to dry a load of clothes, it seems hot enough inside when i open it but the clothes used to dry in 90mins or so now its hours
Have you checked your lint filter? Do you empty your lint filter after every load? If it is hot inside the dryer then the most likely suspect is a clogged exhaust vent. Check the lint filter, if it is clean pull the dryer out from the wall and disconnect the exhaust hose. You may have to clear out the exhaust hose...compressed air usually does the trick. After you have done this, put everything back together and your problem should be gone.
Sep 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
I have a GE Frontloader Dryer, model# SBSD227FWW
common problem result from you having a clog in your home vent.....wil need to check outside vent while unit is running on air dry for air flow....could also be a vent motor failure....depending on unit it may have a motor just for the exhaust fan.
Jun 30, 2009 | Dryers
Dryer runs for long time and does not heat up to dry clothes
Check first to see if the lint filter is clean and the vent hose is clear. If the filter is clean, the vent hose is unblocked and not crimped, and the exterior vent is clear then you probably need to replace the heating element.
Hope this helps. Good luck.
May 17, 2009 | Dryers
Lint vent
There is no lint filter in this machine, however, the condensing duct and condensing bellows can get be a problem later on if it gets jammed up with too much lint.  If you notice that it takes 50% longer or more to dry your clothes, you will need to have the duct checked and cleared out of excess lint buildup inside.  Not an easy job but it can be done.
Nov 28, 2007 | LG WD-3243RHD Front Load Washer / Dryer
Dryers Logo
204 people viewed this question
Top Dryers Experts
Marvin
Marvin
