I worked for a day and now won't turn on or do anything and I have changed the battery uncountable times and now have no idea what to do now
SOURCE: kodak easyshare z1275 not working =(
PROBLEM - Camera will not turn on at all regardless of battery used. Happened after about 8 months of use. Kodak instructed me to send the camera in of warranty repair. MCU was replaced. The unfortunate thing is that I have the same problem again, 7 months later and I am guessing it is not a warranty repair this time.
SOURCE: it won't turn on and i have not dropped it
If your Kodak is less than one year old, then it will be repaired for free, under Kodak warranty, see Kodak Professional: SUPPORT CENTER or contact the number listed on the owner manual.
SOURCE: My Kodak EASYSHARE M1063 camera won't turn on
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: My kodak easyshare V1003 camera will not turn on.
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: kodak easyshare Z740 battery problem
I may be able to help with your Kodak EasyShare Z740 that turns itself
off.
Try these steps to fix your camera.
I
hope that helps.
_____________________________________________
Turns Off Fix
Manual Download
