Question about Sakar (01717) Mouse
M00117-MB right click button doesn't work
M00117-MB Mobility Mini USB Retractable Optical Mouse.
Right click button doesn't work, doesn't do anything. Everything else is fine.
My problem is with the left click. I buy there mouses because they're cheap, but I suspect foulplay: Planned obsolescence! They always start to break down after a while for apparently no reason and then you're off looking for a new mouse, but then again I could wrong, maybe they're just generally not built to last or for heavy usage.
Next time I'm doing my homework on which companies make quality mouses so I won't have to keep replacing them - I suggest the OP and others who have problems with Sakar do the same.
Posted on Mar 15, 2010
How to change batteries to mini optical mouse
There are no batteries. It's a wired USB mouse.
Apr 26, 2014 | iHome Optical Mini Travel Mouse W...
No results from right clicking
if you can hear by ear after you click right button same sound as when you push left button, then it will be software problem.....
if you can't hear same sound, then microswitch is broken, or not in proper possition.....
if it's software problem, try to plug it into another usb port, or somebody elses computer, then you will see if problem persists also there....
if it doesn't work on another computer, then it will be mouses problem.... take it back to bookstore and ask them for refund or exchange
Mar 25, 2014 | Targus Mini Kaleidoscope Optical...
Mouse driver for m00117 laptop running win 7 does recognize mini mouse need driver
click start control panel under harware and sound view devices and printers you should see your mouse right click select open download mouse software
once your usb mouse is connected windows 7 should automatically search for and update the drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red Xthis means a driver will need to be updated right click select update driver
Oct 18, 2011 | Sakar Optical Retractable USB Mouse...
My SYLVANIA mouse model # SY-040R is not working. It worked for about a month and then stopped working. It is a usb retractable optical mouse. Please Help!
optical mice suffer issues like anything else, just because it has no moving parts, doesn't mean it's never going to quit.Try the obvious, move the mouse to another port on this machine or another machine, to confirm the malfunction, after this I would encourage you to take your newly confirmed mistake back to the retailer, as it is only 30 days old.
Jun 08, 2011 | Computers & Internet
M trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like. much thanks!
Optical mouse from inside: http://www.gadgetrivia.com/photos/o/56422-best_optical_mouse.jpg (this isn't a retractable mouse, but the inside looks exactly the same, only the cord this different which doesn't matter in this situation).
Here are instructions for optical mouse repair: http://www.thenetguruz.com/hardware/diy-optical-mouse-repair/
But if your mouse doesn't work first plug the mouse in the USB slot and check the laser beam under the mouse - if there is no light, the mouse is dead, and you should return it to the seller for replacement. (Such a thin cable of the mouse is very vulnerable and might break easily. More over I find many negative reviews about this rectractable mouse - so if your seller offers to replace it - ask for a different model or test it with your laptop right in the shop before bringing it home.)
2) Here is a solution that already worked for another user, but was very complicated: http://forums.toshiba.com/t5/Keyboards-Touchpads/USB-mouse-not-recognized-drivers-can-t-be-installed/m-p/23526
3) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
Apr 10, 2010 | Generic Memory Mini Retractable USB...
My mouse isn't working, but I don't know if the problem is the mouse or the UCB drive. it doesn't work in any of the USB ports after no problems for a year of having the computer...thoughts?
turn it upside down and see if your mouse has a red light on ... if not most likely your cable has been cut/broken ... after all it's a low quality mouse ...
replace it ASAP
Sep 10, 2009 | Innovera Optical Mini Wired Mouse...
Stopped working
Hey,
Goto device manager by right-clicking My Computer-> properties-> hardware-> device manager.
There in mice and other pointing devices category, select your mouse, uninstall it and refresh the page.
It should automatically detect your mouse.
Thanks
Apr 15, 2009 | Toshiba Black/Red USB Laser Mini...
Won't work with PC
Hi alot of people have problems working out the wireless devices. You need to plug in the USB reciever load windows till desktop appears, hold down the reciever button until it flashs then quickly turn over mouse and press connect button in. and you should see the reciever flicker, and it should start working. if it dont try swapping the batterys as they dont last long... Hope this helps John
Feb 26, 2007 | IOGear 800 dpi USB Optical Mini Mouse...
Sakar (01717) Mouse Logo
316 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Jim Thurston
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
