Question about Dell Inspiron E1705 Notebook
Coputer wont charge even when pluged in
My computer wont charge even when i plug it in. if i fiddle with where it plugs into the computer it starts to flash charging/notcharging. it will remain charging if i apply constant preasure in a specific direction. (direction and amout of preasure required varie)
  • Dell Master
  • 32,281 Answers
This is a commom problem.
Problem with power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Posted on Jul 01, 2009
My laptop pluged in but not charging
There could be many problems with your laptopFirst, check if your laptop was plugged into a surge protector (ex. Power Strip). If it wasn't, a surge could destroy the charger, power supply, or even motherboard.
Second, try a different charger. If it was the charger that broke, then try a different one. I have had this happen to many off my computers over the years.
If it is fried, take it to Staples, or a local computer shop. I would always recommend plugging computers into surge protectors. Good luck!
Feb 05, 2012 | Compaq Presario CQ62-215DX Laptop
Car runs strong then stalls out. it wont start for awhile about 20 minutes then starts again. took it to big o but they couldnt figure it out, they think its a electrical problem. they could not do a...
i have the same problem with a car.. usually its the air charge sensor. Although replaced the air charge sensor and Map sensor and still same issue. bad smell of gas from exhaust cat pluged up replaced it still same problem. did a tune up (plugs and wires) now car wont even try to start cranks all day fuel pressure is good at 40psi also
Nov 26, 2010 | 1989 Buick Regal
I just installed the driver software for a Brookstone Photo Scanner (SKU No. 63494) on my HP computer that uses Vista Software. Now nothing on my coputer functions. I can not even get the thing to shut...
Did you try switching the computer of a the plug and start it up again,
or do you have a restore disc for the computer,
when you load your software in for the scanner dont have the scanner pluged in
untill it tells you to...
Nov 24, 2010 | Computers & Internet
Wont turn on, plug it into comp reads...not enough free space for music DB please free 30MD. my computer does not recognize there is even anything pluged in. the clip says its connected and charged. how do...
Slide the Clip's power switch to the "lock" position, then hold down the rewind button (looks like "<<") while plugging your Clip into the computer. You should then see your Clip show up in Window Explorer as a "removable disk". Right-click on the Clip in Windows Explorer and select "Format". Don't select "Quick Format", and be SURE you're doing this to your Clip, not one of your computer's disks.
After the format is done, unplug the Clip, plug it back in and verify that you no longer get the "not enough free space" message.
Jan 26, 2010 | SanDisk Sansa Clip MP3 Player
Cliq wont charge
Replace the data cord and try to connect it will work
Dec 05, 2017 | Motorola Mobility CLIQ Cell Phone
The computer
yes it has everything to do with the running. it is the CDI
Sep 20, 2009 | 2004 Yamaha XT 660 R
My laptop wont charge
Sounds like to me you may have a bad battery. I would do a search for your model number for a battery. It is showing being plug in that means your charger is working, but your battery not taking no charge.
Aug 09, 2009 | Dell Inspiron 1525 Notebook
Inoi MP3
I have the same problem, sometimes, if I plug it up to the computer, with usb port and press the computer option, keep pluging and unpluging over and over it will reset and starts working again. But it still fails, It may have something to do with the internal battery being weak. Even thought it shows charged, may not be able to supply the current required to start the hard drive.
Jun 11, 2008 | INOi MP18020 GB MP3 Player
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
Dell Inspiron E1705 Notebook Logo
98 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
