Question about M-Audio US85100 Keyboard
Notes that won't sound
I have an M Audio Keystation Pro 88 that's 2 years old. Abruptly, three adjacent notes won't sound when they're played, and I can't enter these notes into Sibelius. What should I do?
  • 1 more comment
  • workshop Nov 15, 2007
    C two octaves above middle C sounds inttermittently. Sometimes it will get stuck and continue to sound with the key not pressed. This is an M-Audio ProKeys 88, about two years old also. I have sprayed canned compressed air into the keyboard from between the keys and also from the back (removing the back metal panel).
  • Anonymous Dec 31, 2007
    Same problem with stuck notes. For me it's middle C and the Bb just below.  Must be contacts - anyone know how to get the case apart to clean contacts?
  • Anonymous Apr 04, 2008
    3 keys are sticking around middle C, the most used area. I cannot figure out how to remove the front panel to see what the problem is. How do we remove the front panel to look at the mechanics of the keys?
Try to reset the keyboard. Locate the numberpad on the Keystation Pro 88, press and hold down the + & - buttons while powering on the device. This will reset the device but any stored presets will be lost. I hope this helps...more information can be found on M-Audio's website.
Posted on Sep 07, 2008
I have an M-Audio Keystation 61es. Lately I've had random loss of power through the USB2.0 cable. The cable still powers my other M-Audio products, so the issue is the Keystation. It is possible...
I have the 88 key ones and powering via the USB is marginal... IF you have a place for an adapter, use one, as the computer USB is limited to 1/2 amp and OFTEN they limit at a little less and then the keystation is not reliable...
Aug 30, 2011 | M-Audio Keystation 61es USB MIDI...
I recently purchased the Keystation 88es and I have installed the Able Live Lite 6 on my computer. I have installed the USB MIDI series 5.0.1 from the M-Audio website. I have plugged in the usb port as...
First step is to download Midi Monitor
just to make sure you're actually getting midi over USB into the computer. This is a great utility that I use all the time for troubleshooting midi data issues.
Feb 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
The "G" note below Middle
The key contact has gotten contaminated. They are a black conductive rubber pill pressed against circuit traces on a board bellow the keys. Remove that key and maybe others to get at the contacts in silicone strips. Clean ONLY with 99% isoprophyl alcohol and Q tips. Clean both the pills (two per note) and the circuit traces they touch. You have to release the spring at the back of each key to remove the key.
Feb 03, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
I just bought an M-Audio Keystation 88ES. I have a used Behringer expression pedal. The pedal works fine in the sustain input, but when I insert the jack in the volume input it cuts all power to the...
If the power goes off when you plug in the pedal, the pedal LIKELY has a short in it between two of the three connections at the plug.
Firat, try putting the pedal plug in BEFORE applying power.
Likely the pedal presents a pot or volume control that will have like 5 volts across it an the wiper returned on the same cable. If the wiring configuration is wrong OR if the plug goes through a period of shorting the 5 volts out during insertion that will cause a problem...
To troubleshoot, move the pedal to half way and these with an ohmmeter for shorts between ANY two of the three connections.
Jan 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
My child jammed something inside of my keystation pro usb connector.... Broke the copper connectors inside.... Whats the best way t go about this ... replace the entire piece or soder in a new copper line
If the traces are lifted, then use jumpers to the points of origin of each trace. Tack the jumpers down with silicone seal or other adhesive.
Replace the connector ifthere is any chance of damage to the connector itself.
Oct 14, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
Keystation 61 key won't play
Most of these use conductive rubber pills that are pressed onto circuit board traces by the keys.
Clean the board AND the pills with 99% isoprophyl alcohol and QTips.
May 31, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
M-audio ProKeys 88sx -- all led lights flash, no sound Upon turning the keyboard on, all led lights on the top panel flash. No sound from the keyboard. Is there a re-set button or something?
I have two of these. First thing check your power adapter for output. Just because LED's are on doesn't mean there is correct voltage... There is no reset button... Cycling power serves to reset it.
ALSO check the power input connector... sometimes those get intermittent and break connection due to vibration and initial current surge when turning on.
M-audio 88es, I plug into my laptop using windows xp and no sound
You have to install software to connect the device to the General MIDI input. This rquires a driver for the 88ES.
Mar 08, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
Open Questions:
See all M-Audio US85100 Keyboard Questions
M-Audio US85100 Keyboard Logo
657 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
