Question about Acer Aspire 9402WSMi Notebook
Acer 9402WSMi laptop with a broken lid.
I have an Acer 9402WSMi laptop. The lid broke at the left hinge. The monitor itself is still good. Where can I find a new lid?
  • twiggt Jul 01, 2009
    Thanks for the reply. But I do need the top of the case. It is broke from the hinge to the outside. I cannot close the lid.
  • Acer Master
  • 32,281 Answers
You may not need to replace the lid just the hinge.
Try this WEB site for Acer parts.
Use this link :-
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
Posted on Jul 01, 2009
Lapcover cover lid craked by lhs hinge 9420 acer aspire
You are to contact Acer with the issue. If they've written down your comment on the tight operations then (perhaps) you're in luck to get it replaced as per warranty.
Mar 28, 2017 | Acer Computers & Internet
Labtop broken hinges broke off computer still works fine just top monitor doesnt stay up snapped from hinges
here is a Ebay listing for laptop hinges for the 9400 series
http://cgi.ebay.com/ACER-Aspire-9300-9400-9520-laptop-17-LCD-screen-hinges_W0QQitemZ120549686747QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c11523ddb
You will have to install them or find a person who is handy with disassembling laptops.
1. You will have to remove the cover of the LCD screen and then you will see the hinge support assembly.
Here is a site that may assist you with the taking apart and assembly
http://www.insidemylaptop.com/fix-broken-dell-laptop-hinges-yourself/
Apr 14, 2010 | Acer Aspire 9410 Notebook
Acer laptop loose clock time
yes it has a cmos battery, inside you would have to disassemble it to replace it.if you have never taken a laptop apart the i'd recommend a service center.you can do a lot of damage if not familar with the disassembly and reassembly process.
Aug 03, 2009 | Acer Aspire 9402WSMi (LX.ACJ05.001R) PC...
Left hinge broke and no screen.
Its possible that there is a cable loose causing a short, which could have happened when the hinge broke.
This would explain why you are not seeing any display. To test if the display is bad, or if the computer is just not working, you can plug in an external monitor. It will help you to see if you nicked the cable, or if the system board is going.
Jul 23, 2009 | HP Pavilion DV9650US Notebook
Gateway left hinge broke
Definately an easy fix.
I suggest looking on eBay for a donor chassis.
Sometimes they can be had relatively cheap CLICK HERE (this one has both hinges broken however) - and sometimes just the parts you are looking for are available CLICK HERE (this is for the RHS one though).
An entire donor PC is adviseable, because usually the repair is not just the hinge that broke - as the rest of the lid is plastic!
Once the trim above the keyboard is pried off, you will see the monitor cable, and hinge screws.
The trim around the monitor must be dis-assembled and pried into 2 parts.
Then the hinge & Support are either screwed into the side of the screen, or the back of the lid.
Most look like this...
Replace reverse of removal.
HERE is a link that will describe it better and give you a visual reference.
You are interested in step #s 7, 8, 11, 12
Once the screen is free of the chassis - its time to remove the little rubber scerw covers in the lid, and disassemble.
Good Luck!! Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Gateway MX6448 Notebook
Left rear hinge failed on my Acer Aspire 9402WSMi Notebook
It depends if you can prove that the failure isent caused by you. if you can do that Acer will replace it.
Contact Acer and tell them your story. Here in Europe Acers custumer suport is good, dont know how the are in US.
Good luck
Dec 10, 2008 | Acer Aspire 9402WSMi Notebook
Acer aspire 3620 lid broke and screen needs to be replaced
If a 'qualified' tech damaged the screen, then it is up to them to replace the screen at their cost.
You could try finding screws slightly bigger and see if they will realign and stop it from being floppy.
Personally I would go back to the tech and complain untill they repair it properly.
Hope this helps a little.
Nov 27, 2008 | Acer Aspire 3623WXMi Notebook
Acer hinges hard to open google says known issues,will not fix says normal already cracked case above left cant figure how to open
Appreciate the direct "Ask Me".
To your concern; hinge repair is relatively easy, what is more challenging is opening the lid and figuring out how to improve the hinge action to reduce the stiffness of closing the lid. For a pictorial illustration on how to open the lid cover to expose the hinge, please reference this page. For a generic how-to on hinge repair, pls check this out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Acer Aspire 5100 Notebook
Monitor dark; hinges broken
He may have damaged the inverter or left the cables disconnected from the backlights. The inverter supplies the required voltage to the LCD Back lights.
Mar 31, 2008 | Toshiba Satellite A25-S207 Notebook
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 9402WSMi Notebook Logo
228 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
