Question about Frigidaire Electric Dryer
My dryer has two problems, one it doesn't dry the clothes in one cycle. I clean the filter on every load, have cleaned the hose and the tube that is in the wall. Also, my dark clothes is full of lint.
    Sergeant:
    Champion:
  • 235 Answers
Sounds like your bias thermostat is bad. It's the one that has the 4 prongs.
Posted on Jun 30, 2009
Check the area that the lint filter slides into . Usually there are a couple of screws. Take them out and remove that whole piece. Lint gets out and around that lint trap. The whole front panel can be filled with lint preventing the moist air from going up the hose. If your clothes do eventually get dry and even feel hot then that should let you know that the heating element is still good.
Posted on Jul 01, 2009
Dryer takes 3 cycles to dry clothes
Air flow blockage will shut the thermostat down early. You may need to clean out the lint filter holder with a vacuum cleaner or a bent coat hanger. Look inside the dryer vent hose. It probably has a load of lint dust in it. A thorough cleaning is in order.
Oct 01, 2014 | Estate Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
My dryer is taking longer and longer to dry a load of clothes. I clean the lint filter every time I open the door and check the clothes. I am putting fewer and fewer clothes in which, since I am supposed...
Hi, Yes there are thing to check. Due to number of years the lint accumulate and clog the hose and the bent where the hose attach. The hose that is coming from the dryer the might be clog, and that have to be clean including the bent that is going out the house and that hose is attach too. I hope this information will help you to solve the problem.
Jul 07, 2011 | Dryers
My dryer seems to be heating up but the clothes take two cycles to dry.
sounds as if the vent is restricted, take vent tube off, dry a load of clothes. Clean vent tube, and you may want to clean the inside of the dryer,also. Hope this helps Tim
Apr 04, 2011 | Frigidaire Electric Dryer
Dryer takes too long to dry clothes. Heating element is working because clothes are hot but it takes almost 2 dry cycles to dry clothes.
It sounds like you're lacking air flow. I'm sure you're cleaning the lint trap / filter - but have you clean the VENT HOSE / PIPE?
The 4 in vent hose is supposed to be cleaned annually. If you have the flexible vinyl hose, replace it with either steel, aluminum or flexible aluminum tubing instead. Once you've removed the vinyl hose, it will collect a lot less dust and can be cleaned without worry of puncture.
A typical dryer vent brush.
Make sure there's no obstruction to the flap outside, too. Once cleaned the dryer operation should be restored to new again.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 09, 2011 | Dryers
I have a GE clothes dryer model DBSR453EB3. It seems to heat up properly but takes entirely too long to dry a load of clothes. I have cleaned the lint hose. Can you help me out here??
ck cabinet and element housing for lint ck motor blower housing and discharge tube also if cleaned and still does it ck that limit switches are not short cycling due to weak bimetal disc
Jan 26, 2010 | GE DCSR483EA Electric Dryer
Not drying as quickly, requires 2 cycles
look inside your lint trap to see if it is clogged. Also remove your vent hose to check for clogs there and at the outlet. make sure your hose isn't kinked.
Jul 20, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Jan 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
6th cycle and clothes are still extremely wet.
Are you cleaning the lint filter after each load?
(Pull it out of the top of the dryer or inside the door and clean it )
Can you go outside and find the vent where the dryer exhausts air? when the dryer is running with clothes in it, is there air coming out? If not, It is plugged.
Whether you think it is pluggged or not,, go back inside and pull the dryer out from the wall carefully. If it is a stack job, get help!
Now the 6" diameter rippled tubing that connects from your dryer to the wall can be removed by loosening the clamp on the dryer with a screw dryer. I think you should carefully unplug the dryer before you start this!
Loosen the clamp and pull the hose off the back of the dryer. It may be full of lint and all sorts of interesting things which you need to clean out. Or you may find that it is not even connected. When you are satisfied that it is clean. place it back on the dryer (MAKE SURE it is not twisted) and tightened the clamp back on very well with the screwdriver. When you push the dryer back in place be careful not to push it in so far that you collapse this vent hose or twist it.
That's the dryer. NOW, when you remove the clothes from the washer do they feel still full of water? Is the washer spinning well and removing most of the water? If it is not this can cause your dryer to take forever to dry the clothes and it can also cause your dryer to overheat.
Whether you have a pile up of lint in your lint filter and hose or the washer is not spinning correctly, both are a huge fire hazard for the dryer, so TAKE CARE of this NOW. Please. and Good luck!
Aug 12, 2008 | Roper REX4634KQ Electric Dryer
Frigidaire  Electric Dryer Logo
330 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
